Headlight noise
Old Jan 22, 2007 | 08:42 PM
biglu187's Avatar
biglu187
Default Headlight noise
I'm hoping I already know the answer to this one but since everyone was so helpful on my last one I thought I would ask. I have done a search but can't find anything.
When I turn my lights off on my C5 they go down but the drivers side makes a brrrrr sound for about 5 seconds. Is this because the gear is stripped out? It goes all the way down but I think the teeth are shot at the end and it doesn't see the down sensor and just times out. Am I right?
I have seen rebuild kits for this. Has anyone done this? If so, is it hard?
Old Jan 22, 2007 | 08:45 PM
Blowndave's Avatar
Blowndave
http://www.ecklers.com/product.asp?p...dept%5Fid=1154
http://www.ecklers.com/product.asp?p...dept%5Fid=1476
i just rebuilt my r/f motor using the regular plastic gear. took about 30 minutes....
it was very easy! the 3 bolts are kinda a pain to get out but be patient with them!
Old Jan 22, 2007 | 09:14 PM
ICUALL's Avatar
ICUALL
Default Great Quality
I got mine here http://www.bfranker.badz28.com/headlightfix/index.htm very high quality and great price. The fix is not hard once you get the motor out...
http://www.bfranker.badz28.com/headl...tm#MetalGuide2 shows Firebird & Trans am but yiu can follow most of it for the vette !
Old Jan 22, 2007 | 11:43 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
http://www.rodneydickman.com/retail_new.html
click on electrical and scroll down to headlights
I see you have a 2000 model. Be sure and visually check to see what headlight motors you have, because 2000 was the dividing year. Early 2000s had the aluminum housing that bolts together and later 2000s had the plastic type. The kits are slightly different and the rodney dickman ones come with a brace that really helps if you have the plastic type, like I do. I did both mine about 6 months ago and have had no trouble out of them since.
To Headlight noise
