Clutch Pressure Plate
Old Jan 24, 2007 | 08:09 PM
jmiller's Avatar
jmiller
Default Clutch Pressure Plate
Can you use a pressure plate from a manufacturer that is different than the clutch disk?
For example, Spec has an aluminum pressure plate. Can I use that pressure plate with a new stock ls1 clutch disk?
I can buy a new clutch disk for $68 on ebay. Spec has their aluminum pressure plate for $175. would this combination work?
Is this a bad idea? My car is stock. No racing, just daily driver.
Old Jan 24, 2007 | 08:25 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
you get what you pay for
you might want to look at the LS6 or 7 clutch, farely inexpensive
