C5 Torque Specs
Old Jan 25, 2007 | 04:38 PM
tjZ06's Avatar
tjZ06
Default C5 Torque Specs
I looked in the stickies in the General section but all the torque spec links were dead. Does anybody have a good reference for C5 torque specs? Thanks!
-TJ
Old Jan 25, 2007 | 06:09 PM
brentg454's Avatar
brentg454
http://www.ls1tech.com/forums/showpo...9&postcount=49 Everything you need to know.
HTH,
Brent
Old Jan 25, 2007 | 06:44 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
David Farmer used to have this on his website, I've got them laminated and attached to the lift
now that the above link has loaded, that appears to be the same list
Old Jan 25, 2007 | 06:55 PM
tjZ06's Avatar
tjZ06
HTH,
Brent
Being that that's posted on LS1tech, and some of the options on the page list 5.7L or 3.8L I'm curious if that's for Fbodies not Ybodies. Though tie-rod and such is listed under the rear susp. which makes me think Y... but then there's Torque Arm which is F...
Hmm.
-TJ
Old Jan 26, 2007 | 09:30 AM
brentg454's Avatar
brentg454
Aha, didn't think about that. I have used that chart for all my engine work, so that would obviously be the same. But the 'spension might be different, though...
Old Jan 26, 2007 | 09:45 AM
Red903L's Avatar
Red903L
Hmm.
-TJ
The first thing I spotted was "Wheel Nut" 89 lbs. .....I may be wrong but I think the C5 has always been 100 lbs., hasn't it?
To C5 Torque Specs
