High Oil Pressure
Old Jan 26, 2007 | 02:51 PM
Choreo's Avatar
Choreo
Default High Oil Pressure
I have seen all the posts on the oil pressure sensor failing and pegging out the oil pressure gauge. My gauge usually reads about 44psi. My question: Is there and condition other than a sensor failure that could actually cause the oil pressure to increase to 80psi? I know in the past there were always concerns about low oil pressure, but I can think of no mechanical condition that would send the pressure through the roof?
Old Jan 26, 2007 | 03:47 PM
65GGvert's Avatar
65GGvert
If it reads 0 key on engine not running and 80lbs when you start it, it's the sender.
Old Jan 26, 2007 | 04:48 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Yes, running your car to 4000rpm or beyond would cause it to increase to around 80psi
Old Jan 26, 2007 | 04:53 PM
Oldvetter's Avatar
Oldvetter
Colder oil will increase pressure at startup also.
Usually when the pressure sender fails, you will get a reading with the key on and the engine not running.
Old Jan 26, 2007 | 11:26 PM
Choreo's Avatar
Choreo
Got it! Thanks.
Old Jan 27, 2007 | 12:02 AM
Jeff Jeff's Avatar
Jeff Jeff
If your dash gage reads 80 psi, and the DIC indicates 127 - 128 PSI, your sender unit is bad.
Old Jan 27, 2007 | 11:03 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I'm dealing with this now as well. Mine finally went bad after numersous years of faithful service. I replaced it with the GM new number 12573107 and a month later, its dead again. I suspect its leaking as well since I can smell a slight oil burning odor too. I ordered the aftermarket PS308 which should arrive today. Will try to gen up a relocation tubing setup so that I won't have to pull the intake again after this. Wish someone had a simple extension tube with the right fittings on it already, like a stainless flex tube. Can't find anything so far.
Old Jan 27, 2007 | 07:10 PM
biglu187's Avatar
biglu187
Mine started doing this last night. I have been trying to find some pictures of where this is located. Can someone hook me up?
Old Jan 27, 2007 | 07:41 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
I'm just waiting for one of the wonderfully talented forum sponsors to produce a kit, maybe with the later Buick sender and I'll be there in a heartbeat! Is this mike on, can you hear me!
To High Oil Pressure
