Big Cam only guys, step in
Old Jan 28, 2007 | 10:57 PM
happa's Avatar
happa
Default Big Cam only guys, step in
Ok I know every Vette is different, but i have a G5X3 and I want a bigger cam with out flycutting. What cam are ya'll runnin and what numbers ya'll puttin down. Thanks for the help!
Old Jan 28, 2007 | 11:51 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Old Jan 29, 2007 | 12:28 PM
kromberg's Avatar
kromberg
Grand Am Cup cam, no fly cutting required on a stock shortblock: 239/251//578/578//106
Keith
Old Jan 29, 2007 | 04:34 PM
Vette-Red's Avatar
Vette-Red
238/242 .609/.615 111lsa. 431hp and 399tq. But, it really feels like I need a gear change now. No flycut needed.
Old Jan 29, 2007 | 04:41 PM
kromberg's Avatar
kromberg
Really with large of duration and lift
Keith
Old Jan 29, 2007 | 05:18 PM
Vette-Red's Avatar
Vette-Red
Keith
What's that supposed to mean? Questioning the #'s?
Old Jan 29, 2007 | 05:36 PM
402Sam's Avatar
402Sam
That just seems to be really tight without having to flycut.. I thought 610 would be the highest lift one could go..
Old Jan 29, 2007 | 05:42 PM
aweil's Avatar
aweil
I have an MS4, 239/242 .651"/.609" 111 LSA and didn't have to flycut with stock valves and unmilled heads... with bigger intake valves and milled heads I had to flycut the intake.
Old Jan 29, 2007 | 05:56 PM
happa's Avatar
happa
what are the numbers? also say i got this cam and I got heads and intake later down the road, what would I have to do. Sorry little confused on the flycut the intake part. Thanks
Old Jan 29, 2007 | 06:01 PM
XPC5R's Avatar
XPC5R
There is a G5X4 which I believe is a no flycut on stock heads. It's the shaved heads and oversize valves that generally require flycutting.
The TRex cam was really popular in the stock head F-body world when the G5X3 was out, and it was bigger and meaner, and made a bit more top end power. Not much else out there with more duration and left, the grand am cup cam has less left and less aggresive lobes.
Lots of good info and specs of the common big cams here: LS1tech cam sticky
eg:
G5X2 232/240 .595/.609 112 or 114+4
G5X3: specs unreleased but bigger then the X2
TR Trex 242/248 .608/.612 110+2
Old Jan 29, 2007 | 09:58 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
eg:
Grand Am cam
2.02 / 1.57 , Int/Ex
Heads milled .055"
Pistons Flycut .080" / .100".
FWIW.
Old Jan 29, 2007 | 10:50 PM
jbusmc1986's Avatar
jbusmc1986
St. Jude Donor '06
With the MS4 you dont need to fly cut, I am about to install mine with my new stg 1 prc ls6 heads, I wont need to fly cut the pistons at all. That combo with a fast 90mm intake and tb made something like 550 hp on a engine dyno, with a stock bottom end.
Old Jan 30, 2007 | 02:19 PM
bayarea's Avatar
bayarea
i run a t-rex 243/249 .611/.614 on 110
Old Jan 30, 2007 | 03:07 PM
Vette-Red's Avatar
Vette-Red
Do you have an exhaust clip/video?
Old Jan 30, 2007 | 03:55 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
I'm running a G5-X2 on a 114... my sig has the idle video in it. However, I took the borlas off for some Corsa Indy's this past weekend.
To Big Cam only guys, step in
