342 diff in 99 a4
Old Jan 30, 2007 | 09:16 PM
firstvette99's Avatar
firstvette99
Default 342 diff in 99 a4
will any mods need to be done to the trany because of the higher rpm in normal driving.
thanks
scott s
Old Jan 30, 2007 | 09:22 PM
c5mtl's Avatar
c5mtl
I have the same thing in my 99a4 with a 3500 t/c...all i added was a trans cooler
Old Jan 30, 2007 | 09:29 PM
Mike Mercury's Avatar
Mike Mercury
it's the higher stall TC that would require an external cooler.
Just the rear ratio swap alone - and no need for an external cooler.
Old Jan 31, 2007 | 03:30 AM
c5mtl's Avatar
c5mtl
you are correct.....but add a tranny cooler anyways....and while your at it ...toss in a 4000rpm stall then u will be really happy
good luck
Old Jan 31, 2007 | 01:12 PM
DJMRTS's Avatar
DJMRTS
When going to 3:42 gears, you may want to get someone with a handheld tuner to reprogram your computer so it knows that it is there. This is required especially if your C5 came with 2:73s. Your C5 came with either 3:15 or 2:73 gears, so your speedometer will be wrong and some weird things happen when using the criuse control. A tranny cooler is always the better way to go! I have mine stand alone and not inline with the radiator cooler. My typical tranny fluid temp never exceeds 165*. When I run hard it may sometimes get to 175* on a hot day. Before I added the cooler, my temps went as high as 230*- thats hotter than your average motor oil temps! Also, almost all factory 3:42 carriers always leak! Not much, but they do leak!
Old Jan 31, 2007 | 05:13 PM
_Will_'s Avatar
_Will_
From: Somewhere between mild insanity and complete psychosis
You would probably want a tune, especially to change your shift points, but the speedometer will still work correctly.
Old Jan 31, 2007 | 05:51 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
The speedometer will still read correctly, the sensor is not off the gear itself like in other cars.
To 342 diff in 99 a4
