question slave cylinder flush fluid
Old Feb 1, 2007 | 11:41 AM
sts57c5's Avatar
sts57c5
Default question slave cylinder flush fluid
the dealer told me i need to get the - recommend flushing fluid in slave cylinder on my 2000 c5 six speed with 40,000 miles.... what you think? also what is approx cost?
Old Feb 1, 2007 | 01:42 PM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
Default Slave cylinder
The fluid in the clutch hydraulic system should be changed as you would your brake fluid. I believe that the dealer will charge you for about 5 hours of labor. There are several threads in this fourm on replacing the fluid yourself, by removing the old fluid from the master cylinder and replacing it with new fluid. This process is repeated several times until the brake fluid remains clear after several days of use.
Doug
Old Feb 1, 2007 | 03:24 PM
97C5ENVY's Avatar
97C5ENVY
Doug
Use a turky baster to suck out the old fluid.
Old Feb 1, 2007 | 04:16 PM
sts57c5's Avatar
sts57c5
thanks I called dealer and they said 90 dollars to do the job ?
Old Feb 2, 2007 | 11:37 AM
Boob's Avatar
Boob
That's not too bad if you don't want to do it yourself. They will need to remove your h-pipe, and tunnel plate.
If you lived near me I'd help ya do it.
Old Feb 2, 2007 | 11:37 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
That sounds too inexpensive to me. I would be skeptical as to how much of the system they could drain or flush in the less than an hours time? They may just remove the fluid in the reservoir and top off the level?
Old Feb 3, 2007 | 04:13 AM
LKGRenegade22's Avatar
LKGRenegade22
Doug
Do what he said. Go buy a baster and a bottle of fluid and just change the reservoir everyday you drive it until it clears up. I was having the clutch pedal sticking problem on my 02 Z06 after 55K miles and had never changed the fluid. I changed it everyday (in the reservoir) for about a week and the fluid is now clear and my problem went away. That's something that is just too simple to have to put your car in someone else's hands to get done.
Old Feb 12, 2007 | 10:37 AM
Heavy Hauler's Avatar
Heavy Hauler
what fluid came in the clutch? DOT 3 or DOT 4. I just purchased this car & need to take car of this before I have a problem. I have always heard not to mix 3 & 4, so what do I use?
also what is used in the brake system?
Old Feb 12, 2007 | 11:07 AM
B-ras's Avatar
B-ras
Factory fill is DOT3 in brake and clutch. AFAIK, you're fine to mix DOT3 and DOT4, but avoid the DOT5 silicone-based stuff. I've been using the turkey baster (actually mixmizer syringe) method to keep fresh Prestone DOT4 in both.
Old Feb 12, 2007 | 11:39 AM
Heavy Hauler
thank you
To question slave cylinder flush fluid
