Need help softening ride-too harsh
Old Feb 3, 2007 | 11:07 PM
RoadVette1999's Avatar
RoadVette1999
Default Need help softening ride-too harsh
Hi all! Happy New years to everyone. I have been procrastinating for about two years now. I changed my suspension system several years back. This is what I did.
Z06 sway bars
Z06 springs
Bilsteing sport shocks
Micheline Sport Tires
Lowered vehicle all the way (slammed)
Love the look-HATE the ride!
I realize that I should have taken things slowly, but I was doing a whole bunch of mods at the same time.
My question is this. I want to soften up the ride without changing everything out. I thought about raising the car, but am uncertain how high I can go back up with the Bistein Sports. Should I try this first, and if so, how high can I go, stock Height? Should I just change the shocks and raise the car? Should I go back to stock on everything . I would like to hear everyone's opinion on this!
Old Feb 3, 2007 | 11:16 PM
SLPRC5's Avatar
SLPRC5
Z06 sway bars
Z06 springs
I have the ZO6 SBs and Bilstein Sport shocks and I agree the ride is "harsh", so I'm going to the Bilstein HD shocks. I was told by Bilstein that the HD shocks are 20% softer. Other members said the HD and ZO6 SBs are a good combo with a less firmer ride than the sport Bilsteins'.
Old Feb 3, 2007 | 11:25 PM
FRCTony's Avatar
FRCTony
I would raise the car about a half inch at a time until you like it.
The shocks should be able to handle up to stock ride height.
Old Feb 4, 2007 | 08:46 AM
rkerr1234's Avatar
rkerr1234
Non runflats would help a little
Old Feb 4, 2007 | 01:21 PM
Jeff Jeff's Avatar
Jeff Jeff
I did mine a component at a time.
Changed out the stock shocks for Bilstein Sports. Noticed a much improved ride, definately not harsher, but less floaty.
Two weeks later I did the sway bars. I went with the Hotchkis and they made the ride much harsher, but I was willing to deal with it for the improved handling and lack of body roll.
A month or so later, I lowered it about an inch. Seemed to add some harshness to the ride.
Two years later I put on Z06 springs and raised it back to about stock height. Ride seemed to get better.
Old Feb 4, 2007 | 10:06 PM
JEEP/C5's Avatar
JEEP/C5
I would raise it up a little since that mod is free. Then I would go with the Bilstein HD. I have the HD on my 01 z51 with z06 swaybars and love them. The HD are a little firmer than z51 but handle the rough stuff better and are way better on the interstate overpasses (not as floaty - if that is a word). Im very happy with the HD.
Old Feb 5, 2007 | 12:03 AM
RoadVette1999
Thank you all for your help! I think I will try with raising it about a 1/2 inch. Then I will try the Bilstein HDs. Thanks again guys!
Old Feb 5, 2007 | 06:16 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
I have to agree. My Z51 lowered with C6 front adjusters and 7" bolts in the rear and Bilstein "HDs" rides better than it did when new (owned since new) I also can't see where I've hampered the handling of the car although I don't do HPDEs, just spirited road use. The HDs seem to be a good match to the Z51 suspension and I have to wonder how much of a difference the Z06 spring would bring to the mix. It looks like you're going to do SOMETHING, so please share your results in the future. I think you are on the right track with the softer dampening of the Bilstein HDs.
Old Feb 6, 2007 | 09:04 AM
EHS's Avatar
EHS
Old Feb 6, 2007 | 02:52 PM
Hvymtlc5's Avatar
Hvymtlc5
Non-runflats would help ALOT. Which is cheaper changing shocks or changing tires......
Old Feb 10, 2007 | 06:22 PM
RoadVette1999
Old 55: I will let you know what I end up doing.
For those who keep suggesting getting rid of the runflats, that was one of the firsts things I did. I ended up getting the Michelline pilot sports.
Old Feb 10, 2007 | 06:39 PM
nuke61's Avatar
nuke61
Try something simple first... drop the air pressure in your tires by a few pounds at each corner and see how it feels. Just a few pound of pressure can often make a significant difference in ride harshness. I personally wouldn't go much below 30 psig, but even high 20s should be O.K.
Old Feb 14, 2007 | 12:38 PM
RoadVette1999
Thanks Nuke61, I usually keep my pressure at 25-30 psi. I do not notice any significant changes when the pressure is lower. I live in the suburbs of D.C., which I think is the main problem. I am going to try to raise the car this weekend.
Old Feb 14, 2007 | 12:53 PM
AU N EGL's Avatar
AU N EGL
Well You think this might the corrolation??
RASIE THE CAR BACK UP. Allow your suppension to work the way it was desgined to do.
Old Feb 15, 2007 | 06:13 PM
fdxpilot's Avatar
fdxpilot
The springs will have a big affect on ride. You went with the stiffest OEM C5 springs short of the T1 racing setup, and then slammed it so there is a lot less suspension travel. What did you expect?
Old Feb 15, 2007 | 06:17 PM
AU N EGL's Avatar
AU N EGL
I run a T1 suppension. ROCKs would be softer on public roads. But on the track . .. dead flat cornering and NO body roll.
Old Feb 15, 2007 | 11:38 PM
dagon138's Avatar
dagon138
I suspect that the slammed look is costing you big in the ride dept. Raise it up and see if the ride improves. If it does but you still want the slammed look, I'd suggest getting Coilovers like Pfadts. My Stock suspension and height - Z06 doesn't ride harsh at all.
To Need help softening ride-too harsh
Old Feb 17, 2007 | 07:19 PM
RoadVette1999
AU N EGL and FDX Pilot. I posted this request looking for assistance, not comments that have, "you dumb ***" undertones. Thank you though for taking the time to reply to my post; your comments have not fallen on deaf ears. Besides, isn't moding about learning? Prior to doing my mods, I did plenty of research and came across many that loved the ride and many that hated it. There was only one way for me to figure it out. Now I know what I don't like and will work on fine-tuning my ride. I don't regret the mod, as I had never owned a wrench and now know how to replace a complete suspension; I have also made many friends along the way.
Now, to continue this discussion, dagon138 has peaked my interest. If I did the Pfadt coilovers, do I need to purchase different swaybars, or would the Z06 swaybars work?
Again, thanks to all of you who have offered opinions of substance.
Last edited by RoadVette1999; Feb 17, 2007 at 09:04 PM. Reason: Grammatical errors
Old Feb 17, 2007 | 07:44 PM
RedRider98's Avatar
RedRider98
I too went with Bilstein Sports/Z06 sways a while back and the ride is very harsh. Hitting large bumps in the road is a jarring experience. Oh well, live and learn I guess....
Old Feb 17, 2007 | 09:00 PM
RoadVette1999
Exactly, live and learn
