Removing Door Opening Trim??
Old Feb 4, 2007 | 04:41 PM
Last C5's Avatar
Last C5
Default Removing Door Opening Trim??
How do you remove the rear door pillar trim on a Z06, namely the piece that covers the lower outside seatbelt roller? Do these pieces just pop off or is there some trick?
Old Feb 5, 2007 | 05:12 PM
jers98vet's Avatar
jers98vet
Not sure on the Z but the trim pieces on my vert are just held on by clips. Just pull to remove.
Old Feb 5, 2007 | 05:25 PM
Bill Dearborn's Avatar
Bill Dearborn
Same for the Z. Start with the door sill piece first.
Bill
Old Feb 5, 2007 | 07:03 PM
Last C5's Avatar
Last C5
Bill
Thanks, I was actually thinking about starting at the other end so this is a great tip.
To Removing Door Opening Trim??
