Dic Codes
Old Feb 6, 2007 | 03:49 PM
bassspring's Avatar
bassspring
Default Dic Codes
Need help 10 PCM PO410 HC code says AIR SYSTEM-B what part do I need. bassspring
Old Feb 7, 2007 | 01:56 AM
Bill Dearborn's Avatar
Bill Dearborn
A code does not mean you replace something. It means a measurement was out of tolerance. Many things can cause a measurement to be out of tolerance. You have to use a diagnostic to figure out what is causing the code. The correct code is P0410 not PO410. Here is the diagnostic for that code on a 1997. Other years may have a different diagnostic which you can find on the same site.
http://www.gearchatter.com/viewtopic8567.php
Bill
