ecbm repair (1214)
and after talkin with Brandon got him to repair and upgrade it for 150.00 plus 8.00 for return next day air . this is a great price if ya look at cost to replace and customer service was also great. he will gurantee the ecbm for as long as you own the car.So if ya have this problem give him a call , site is absfixer.com or call 877-648-7530 let him know ya herd about him on the form.
hope this helps
Bill
Mdule connected to the BPMV
Module removed form BPMV
Module inside case "back side" that connects to BPMV:
The module and case are filled with a silicone that makes seperation of the module difficult!
The metal cans on the top board are the electromagnetic driver coils that open or shut the poppet valves inside the BPMV
Here is the top of the upper board:
Under the upper board is a micro processor with surface mounted components, The board sits in a chassis and is sealed inside a stickey guey silicone gel. Your NOT going to fix that board!!
Once you get your EBTCM back from being repaired,,,,are you going to bust it back apart and take pictures of it?
Hope the pictures clear up some stuff.
BC
and after talkin with Brandon got him to repair and upgrade it for 150.00 plus 8.00 for return next day air. Tthis is a great price if ya look at cost to replace and customer service was also great. He will guarantee the ecbm for as long as you own the car. So if ya have this problem give him a call, site is absfixer.com or call 877-648-7530 let him know ya herd about him on the form. i hope this helps. Bill
Also, I contacted him. Altho his web site only mentions the K-H EBCM repair, his $150 price with $8 S/H also applies to the Delphi EBCM used in the C5 Z06. keep this site posted as to your experience with his repair.
The housing is stuck together with a black synthetic fabric seal that has adhesive on both sides. It will come apart. I inserted a thin scraper blade into the joint about 1/8" in a couple locations and it just popped apart.
Seperating the EBTCM electrinics from the housing is a BITCH! You have to pry and pull and pry and pull and pry and pull......until the RTV breaks loose!
BC
BC
