please help!? my check engine light is on what do these codes mean"?
Old Feb 6, 2007 | 07:51 PM
Jhyten's Avatar
Jhyten
Default please help!? my check engine light is on what do these codes mean"?
Please help!? My check engine light is on what do these codes mean?
10-PCM P1416 H C
58-SDM B1000 H
60-IPC B0521 H
AO-LDCM B2282 H
AO-LDCM U1064 H
A1 (or I) -RDCM B2283 H
U1064 H
BO-RFA C2100 H
BO-RFA C2110 H C
Is my car ok to drive? What should i do now?
Can you tell me if one of these is linked to my check engine light being on. Thanks a lot guys!
jake
Old Feb 6, 2007 | 08:19 PM
Jhyten's Avatar
Jhyten
anyone? Please... ttt
Old Feb 6, 2007 | 08:31 PM
BlackZ06's Avatar
BlackZ06
The P1416 is what has turned on your CHECK ENGINE light.
On start up the AIR pump is commanded ON to help with meeting EPA pollution rules. The P1416 indicates that the O2 sensor on one side of your engine did not respond to the AIR pump input.
Either you have a hose that has come loose, or a check valve in the AIR system has failed.
This is a pollution control issue, should not affect the day-to-day operation of your engine.
Old Feb 6, 2007 | 08:33 PM
vettenuts's Avatar
vettenuts
The 1416 is the code that turned on the light. The AIR system is faulting. Since it is only 1416, it is likely the check valve. I think 1416 is bank 2, which unfortunately is behind the head. This system tests the O2 sensors on cold start, no issues driving the car like this.
To please help!? my check engine light is on what do these codes mean"?
