Honker Install Anybody
Old Feb 7, 2007 | 10:40 PM
kidd's Avatar
kidd
Default Honker Install Anybody
Thinking About buying callaway honker would like to know is there any cutting or any extra parts to buy to install and are you happy with yours. Thanks !
Old Feb 7, 2007 | 10:47 PM
thehammer69's Avatar
thehammer69
You have to cut the shroud in the area underneath where your existing air filter box is located.
Hammer
Old Feb 7, 2007 | 11:34 PM
jdmvette's Avatar
jdmvette
Night Owl for life
you also must have a rivet gun...not everyone has one in their tool box.
Old Feb 7, 2007 | 11:36 PM
dndrsn's Avatar
dndrsn
Pop rivet gun at Home Cheapo is about $10.
Old Feb 8, 2007 | 01:34 AM
jbauch357's Avatar
jbauch357
Very happy with mine and the install took less than 2 hours from start to finish...
Old Feb 8, 2007 | 12:13 PM
HRDTOPC54FUN's Avatar
HRDTOPC54FUN
The hardest part is getting the shroud out. Some guys have done the cut with the shroud still in the car using a roto cutter. Be carefull though, you're pretty close to the condensor. I had to remove/replace my shroud because it was already cut for a different CAI. A new shroud is about $35. Putting it back in was easy.
Also, if you have a painted hood liner (I know, most people dont) the front section of the bellows section will hit the hood liner. Not a big deal on a normal liner but it sure is making a mess of my Paula H painted liner. I did everything I could to get it as low as possible, like eliminating the grommets at the rad cover but it still hits.
Whole thing took me about 6 hours, prbly spent 1 of those cleaning up the radiator area.
All an all great quality, huge green cotton filter, relocates the MAF in front of the TB, and looks OEM, just the hood liner thing drives me crazy. You can access install instructions and photos on Callaway's web site.
Old Feb 8, 2007 | 01:56 PM
dndrsn's Avatar
dndrsn
Here is a nice pic that shows a comparison in size of filters for Vararam, Honker, and Stock. It also shows the Honker installed in the shroud. Looks like the Stock and Honker are about the same area.
Picture props go to Humanoid 2.0 at this POST
Old Feb 8, 2007 | 02:42 PM
93vetteguy's Avatar
93vetteguy
Default Diy
You might want to check out this thread:
http://forums.corvetteforum.com/show...light=flip+tie
Looks like this guy had a pretty good ideas, and looks like you get the same results for a lot less money ....Just my .02..... Good luck...
Old Feb 9, 2007 | 10:26 AM
waupachino's Avatar
waupachino
I read the write up, and if I didn't have a Vararam already, I would have done it. I have to say it looked like a very well thought out DIY project.
To Honker Install Anybody
