Adding some AFR 205's.
Old Feb 8, 2007 | 04:45 PM
triblk6spd's Avatar
triblk6spd
Default Adding some AFR 205's.
adding some AFR 205's. i have an MTI T1 cam and stock short block. the cam specs are 221/221 .558/.558 112lsa. will i need special length pushrods? anything else i should know? thanks all.
Old Feb 8, 2007 | 05:46 PM
zeevette's Avatar
zeevette
Should use the stock length PRs, 7.4". Probably a good idea to have the heads shaved down to around 60cc.
Old Feb 8, 2007 | 05:57 PM
vettenuts's Avatar
vettenuts
I honestly don't know, but I do know on the Crane rocker arm kit the pushrods in the AFR kit are 0.100" longer. Not sure why or if it has anything to do with the head setup. You could always PM Tony Mamo, he is very helpful with the AFR heads.
To Adding some AFR 205's.
