** New Coil Relocation Kit **
Here's some pictures...
Top View of Engine Compartment
Side View - Drivers Side
Side View - Passenger Side
Coil view - Drivers Side
Coil View -Passenger Side
I'm going to price this at $295 and that will include all brackets, coil mounting hardware, and ignition wire set. I can also provide a complete coil pack harness to make it a virtual plug 'n play.
Install is straight forward and easy - the most time consuming part is moving the wire looms and splicing the coil pack connectors.
I've been looking for a coil remount kit so my expensive valve covers can be seen and the view of the engine isn't obstuckted by those damn coils
Does your kit come with instructions? Also, I'm assuming you don't supply the coils and that I just use my stock coils.....right?
Finally, does the kit @ $295.00 include the shorter custom spark plug wires and the coil pack wire connectors.....i.e. will I need a longer wire set on each bank from the coils to their source of power since the coils appear to be further away from that source of their power ?! And, is that 4 sets of wires on each side or just one set?
Oh, and are the plug wires shorter than stock plug wires? I've heard about another coil relocation kit, but was told that the spark plug wires on that kit were really long. Does the plug wire length really matter??
Thanks Charlie
