AIR System - Help
Old Feb 10, 2007 | 09:13 PM
RWVH's Avatar
RWVH
Default AIR System - Help
Going to put on headers that don't have AIR tubes. Should I block off the car tubes or remove the whole AIR system ? Will it throw codes if I do remove the system ?
Thanks for the help.
Old Feb 10, 2007 | 09:38 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you dont have tubes on the headers, the system is worthless and YES it will throw codes unless you have them programmed out with tuning software.
You can and should remove the entire system.
BC
Old Feb 10, 2007 | 10:49 PM
LoneStarFRC's Avatar
LoneStarFRC
BC
If your state inspection requires the system to be operable and present, you might want to consider that aspect though.
Old Feb 11, 2007 | 12:28 AM
RWVH's Avatar
RWVH
Thanks for the info, OK has no inspection.
Bill, is there any to fake the system so it will not throw the codes ?
Old Feb 11, 2007 | 08:35 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yep! You either need to have someone with EFI Live , HP Tuners etc... to program that function out of your PCM or Purchase the soft ware and do it your self. Thats it. No secret stuff. You cant go to Walmart and purchase anything to fake it out. It needs to be removed from the emissinns records inside the PCM.
BC
To AIR System - Help
