Now I am screwed
Today as I entered the freeway at entry speed the auto trans accelerated through 1st, 2nd, and third. Upon cruising speed I noticed that the car hadn't shifted into 4th, with resultant lowering in RPM. So there I was 3K rpms at 70 MPH.
The car has 126000 on an auto convertable.
Here is the questions, I know the answer will be painful
Auto trans replacement time? Improper servicing after the flush?
Differential leak, but still serviced, have anything to do with it?
Any good transmission rebuild replacement shops/ kits in SOCAL?
I am a really big hands on DIY guy, so tell me strait.
Thanks. Startin the new year off right.
Unless you have access to all of the special tools needed and the knowledge, I would leve to pros, IMHO.
Good Luck with repairs.
It's almost like all that crud was what was actually holding the tranny together. Seriously, is there really a good reason for flushing the tranny fluid, if there has never been any indications of it's having overheated, or been really abused (like pulling a 4,000 lb boat through the Rockies in the middle of summer), what's the point?
Jeez, I must be talking to myself here......Let's get back to basics, shall we?
To the first poster with the problem.....WHY did you have the fluid changed in the first place?
Where you having any shifting problems to begin with?....that is, before you had the tranny flushed?
IF you had no previous symptoms, THEN it would seem logical to "assume" the shop did something to it....like maybe didn't put enough fluid back in, or whatever.
However, I did post a legitimate question which so far as been seen fit to be competely ignored......and that is I have heard from many others, mechanics included, that it is actually not a wise idea to be having an older transmission flushed like that, for the very reasons that this fellow is having problems.
It causes them "shell out" like that.
In other words, the "shop" may not have really done anything to contribute to the problem.....but the flush itself, is what did the tranny in.
Or was all that stuff I was told over the years just so many "old wives tales"?
Ed
www.rpmtransmissions.com
In answer to the question of why the flush in the first place, all I can say is that 125K seemed to be a good time to get it done, not knowing how the previous owner maintained it.
As part of the dealer sale I requested that the tranny be flushed as bill of sale, something that I thought couldn't hurt.
After changing the filter it would have mega trouble leaving first gear, and the other three were fine. Tried to check the servicing myself, thought it was good. Then decided a flush wouldn't hurt, so I did. Flush went well, the tranny left first, and sequentially shifted fine after that. Fast forward a week and it now will not leave third gear.
I plan on checking the fluid level again, and conversing with the guys at RPM. 125K is a lot for an A4, and I am sure a fresh gearbox wouldn't hurt.
Thanks again.
Good Luck.
