Fuel pump replacement
Old Feb 11, 2007 | 06:06 AM
Z06Samuel's Avatar
Z06Samuel
Default Fuel pump replacement
Hello Everyone,
I will be buying a racetronics pump to replace my factory 2002 z06 unit. I did a search on pump replacement to no avail, any links on instructions?
Thanks in advance,
Sam
Old Feb 11, 2007 | 11:15 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
I use the GM shop manual, even with a manual, it's still tricky trying to turn/tilt the pump/sender assy out of the tank
take your time installing the hose on the new pump, be sure to get the steel crimp collar in correct location
I use the Lingenfelter Walbro pumps, they also have a great 'how-to'
http://www.lingenfelter.com/pdf/c5fu...structions.pdf
Old Feb 12, 2007 | 05:53 AM
Z06Samuel's Avatar
Z06Samuel
Thanks Steve, once again you advice gets me on the right track.
Sam
To Fuel pump replacement
