crank pully
Old Feb 11, 2007 | 09:01 AM
WILLIEA's Avatar
WILLIEA
Default crank pully
I have a 99 and noticed that the crank pully has a little wobble to it. car has 47,000 on it . is this something that I should address right now or get taken care of later on , I dont get on the car too hard its just a sunday crusier. thanks
Old Feb 11, 2007 | 09:06 AM
vettenuts's Avatar
vettenuts
Not to alarm you, but if it goes it can cause other damage. I would get it addressed sooner rather than later.
Old Feb 11, 2007 | 10:29 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
VN's is correct, get that pulley in the scrap bin quickly; you don't want to be stranded with the pulley cutting into the steering rack and tossing the belt
Old Feb 11, 2007 | 06:12 PM
POK868's Avatar
POK868
I was looking for the answer to the same question, also I noticed some belt wine any idea how much and should I go to the stealership or find a good mechanic. Thanks
Jon
Old Feb 11, 2007 | 08:01 PM
Vette19's Avatar
Vette19
My 97 has the same problem. It would be an easy job(disconnect the rack and move) but you need a 4 ton Gorilla to break that nut.My IR impact w/150psi would not budge it.I put it back together and kept on driving the heck out of it.I AINT SKERD !
Old Feb 11, 2007 | 10:32 PM
SilverC5Vert's Avatar
SilverC5Vert
Definitely fix it! I've seen what happens when they come off.
If anyone is interested, I have a brand new factory crank pulled in the sealed box. Paid $170, but will take any offers.
-Rick
Old Feb 12, 2007 | 04:53 AM
BlueThunder2000's Avatar
BlueThunder2000
Vettaholic
While you are at it, put an underdrive pulley -
And why not a cam as well !!
Old Feb 12, 2007 | 04:25 PM
bennettrp's Avatar
bennettrp
St. Jude Donor '06-'07-'08-'09-'10,'13-'14,'19-'20-'21-'22
I've got a 24" breaker bar. Me on one side and a buddy on the other, and it broke loose pretty quickly.
Old Feb 12, 2007 | 06:03 PM
WILLIEA's Avatar
WILLIEA
Default crank pully
thanks for the response I had a conversion with a good friend of mine that worked foe chevy for years, now has his own shop , he said in all his time there he never seen a crank pully come off on its own. he thinks Im parinoid.
Old Feb 13, 2007 | 11:23 AM
POK868's Avatar
POK868
Took mine into the dealer today for them to take look and estimate a repair if required after looking at it and fixing the squeal (a build up of rubber debris on the pulley), they advised that it is designed to have some movement in it, and although mine is moving a little more than specified they recommended that I dont fix it. I am going to get a cam anyway so this will just be fixed at that time. Jon
To crank pully
