C-5 battery
Old Feb 11, 2007 | 09:15 PM
wildcar49's Avatar
wildcar49
St. Jude Donor '08
Default C-5 battery
My C5 sits alot since I got a C6 and the battery started going dead like every week It used to go dead after sitting a month and finallyI put a new one in. I talked to my battery guy and he gave me a new one. In the meantime the new Z owners manual says to leave the car in reverse,so I checked the C5 manual ,also says to leave in reverse. That didnt fix it then my boy used it and took the key out (I never did) and now the car has a fully charged battery after 2 weeks of very cold weather. Seems like that is one answer.
Old Feb 11, 2007 | 10:28 PM
Dave68's Avatar
Dave68
When I had my 68 and needed to leave it a shop, it would inevitably fail to start when I went to pick it up. Why? Because someone would leave the key in the ignition in the "on" position. Your best bet, as you have found out, is to always remove the key.
Old Feb 11, 2007 | 11:11 PM
mwagne16's Avatar
mwagne16
Mine just died after 4 weeks of sitting on a 6 mont old bat.
Old Feb 11, 2007 | 11:55 PM
VetteTech81's Avatar
VetteTech81
If you leave the key in the ignition it causes a very small current draw which over a period of time can run the battery down.
-=Rick
Old Feb 12, 2007 | 09:12 PM
wildcar49's Avatar
wildcar49
St. Jude Donor '08
Evidently that must be part of the problem, thanks
To C-5 battery
