optima v other batteries
Old Feb 12, 2007 | 08:36 AM
Pewter 01's Avatar
Pewter 01
Default optima v other batteries
Can someone tell me if the Optima is worth extra cost? I can get a regular aftermarket for over half the cost of an Optima. What does the Optima give me that the others don't. Thanks
Old Feb 12, 2007 | 09:57 AM
Barrier's Avatar
Barrier
This is one of those highly subjective issues. Some people have had great luck with the Optima....others have had them last no longer then any other brand. My '99 has a replacement Delco high capacity no problems for over 1 year. Prior to that was the original Delco 6 years it was only replaced as a precaution. On my other vehicles I have had great luck with the Costco brand of Batteries ( Kirkwood?), I try to go with the largest # of cranking amps I can. All Batteries are made by only a few manufacturers. I believe Costco is Johnson Controls. I would have no problem with installing it in my Corvette. Had one in my '86. Great Warranty, just bring it back and they replace it..no charge.
Barrier
Old Feb 12, 2007 | 10:00 AM
LRD VDR's Avatar
LRD VDR
Best way I can describe it.....its hit or miss!
Shahram
Old Feb 12, 2007 | 11:37 AM
DefenderC5's Avatar
DefenderC5
My "other" battery works just fine. 89 bucks, 3 year warranty and 1000 cold cranking amps.
Old Feb 12, 2007 | 12:42 PM
Last C5's Avatar
Last C5
A recent conversation with an Optima dealer who carries multiple lines suggested that about 16 months ago Optima's quality control seemed to drop off considerably. I just installed an Odyssey 925MJT with an aluminum hold down #HD925SM. It looks good and I'm saving about 12 lbs over the factory battery and more over the Optima. Now we'll see how it performs and lasts. At least I don't have battery acid setting directly over the main computer anymore.
Old Feb 12, 2007 | 12:44 PM
gorillavet's Avatar
gorillavet
Odyssey Battery. The last battery you will ever need!
Old Feb 12, 2007 | 12:46 PM
my6thvette's Avatar
my6thvette
Some people have reported problems with recent Optima batteries. However, mine is 3 years old and works fine. I went to the Optima because my 2 previous batteries leaked and damaged A/C vacuum lines. One leaked after only 6 months. This is primarily a problem with the side post batteries. I understand that the top post are not that much of a problem.
Old Feb 12, 2007 | 01:41 PM
MadMaxZ06's Avatar
MadMaxZ06
I agree. I've had my Odyssey battery for over 2 years and I love it. 20 lbs. lighter then stock, 1/3 the size, and leak proof.
- Max
Old Feb 12, 2007 | 01:42 PM
MattB's Avatar
MattB
Ya, I'm one of those that have had problems, on my third Optima in less than a year and I think this one may not come back from the dead. Your mileage may vary...
Old Feb 12, 2007 | 02:12 PM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
1. No, No, No No, a thousand times NO
2. Yep--just about.....
3. A huge pain in your azz when it dies permaturely....
Summary--they (Optima batteries) are over priced pieces of sh*t that have a long history of premature cell failure. Buy something (anything) else....
Old Feb 12, 2007 | 02:23 PM
BiggieBoy's Avatar
BiggieBoy
Three in less that a year, huh. I thought I had bad luck when it took me 4 1/2 years to have three of them (Optima Red Tops) die on me. The amazing thing is people still buy this POS....
I've had my Sears DieHard Gold for almost 2 years now, no trouble whatsoever...
Old Feb 12, 2007 | 03:09 PM
jon c's Avatar
jon c
where do you buy Odyssey Batteries???
Old Feb 12, 2007 | 03:10 PM
The Wrench's Avatar
The Wrench
After experiencing the acid leak on the computer first-hand, my only concern is getting a battery that absolutely positively will not puke acid. I assume this Odyssey is a gel or something?
What other batteries meet the "no leak" criteria?
Tks,
DG
p.s. my first Optima died within a year - not too impressive
Old Feb 12, 2007 | 03:36 PM
Thickraybans's Avatar
Thickraybans
Here is a link for Jegs http://www.jegs.com/webapp/wcs/store...0002_743313_-1
Old Feb 12, 2007 | 04:33 PM
DeeGee's Avatar
DeeGee
Here's a poll of over 450 owners.
No poll is perfect but it gives you a good idea of what to expect.
Red Tops don't like being discharged by the way. If you don't use your Vette regularly it may not be the best choice for you. A Yellow Top may be better in that case. AC Delcos are not good batteries IMHO. They often die or even leak without warning. Exide gets a good press.
http://forums.corvetteforum.com/show....php?t=1469503
To optima v other batteries
