Lights on A/C control???
Old Feb 21, 2007 | 05:36 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Originally Posted by bluevette1
I ordered the bulbs and should be here this week. I will keep you posted. I dont have HUD on my 97, so I could use the wedge bulbs in everything else including th eradio and a/c?
Thanks again
Oh Boy.... You lost me! The wedge bulbs? I don't know what you ordered!!!
All of the switches have a sub miniature bulb mounted in a T1 wedge base, or some call it a neo wedge base.
The Radio and A/C do not use the wedgr base, they get soldred directly to the board
The dimmer switch uses a wedge base and bulb that is even smaller then the other switches.
You can use the T1 bulb covers everywhere. You'll have to trim the bottom and add a spot of glue for your dimmer switch.
The Neo Wedge LEDs can can be used directly in all buttons and switches minus the Dimmer/HUD.
Old Feb 22, 2007 | 11:26 AM
bluevette1's Avatar
bluevette1
I got the bulbs yesterday. I ordered the ones suggested by dgrant. I was just curious about the different colors I could get like the red you have. So if I can use the bulb covers, I will do that. Where can I get some of those? Is that what you put on the neo wedge that you have in the pic?
Old Feb 22, 2007 | 04:28 PM
tstar's Avatar
tstar
I got the bulb covers from;
http://www.mcmaster.com/
in the "Find Products" field (upper left) type in "16925K11"
You want the "Colored Light Bulb Covers"
For Bulb O'all Pkg.
Type Dia. Height OD Qty. Per Pkg.
G T1 1/8" 19/64" 5/32" 10 16925K11 $3.78
Click the part number and then you can select your color on the left and then order them...
Old May 8, 2007 | 11:56 AM
Vettevrooom's Avatar
Vettevrooom
Cruising
I've searched for days and find nothing on how to get to the HVAC panel bulbs. How do you get the panel off, does the clear window come off to go in that way?
Isn't the correct number on the bulb for replacement like other bulbs?
I just replaced the turn/twilight bulbs using suggestions in another thread for reaching in behind the headlights, but the manual listed the wrong number for the bulbs. The correct bulbs, according to the store computer, were the same number as the old ones in car. I have a late production 2000.
What I couldn't understand was the base on the old bulbs were burned brown/black as though they were the wrong ones. ?? Thanks for any direction you can give me.
Old May 8, 2007 | 03:10 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I did this to mine when the lights were very dim!
Did the soldiering and came out absoloutly perfect!
Takes no time flat, picked up a new soldering kit from radio shack $7.00 and went to town and -DONE! Like New!
Thanks,Matt
