Help with strange A/C problem, please!
Old Feb 13, 2007 | 01:41 PM
randomus's Avatar
randomus
Default Help with strange A/C problem, please!
My A/C in my dual climate control is acting really wierd, it comes on in the defrost mode in the morning but when I need A/C when it gets hot I only get the recirculation fan on. Here's what I've tried so far.
Checked for codes, no codes at all.
The external temperature sensor reads about right on the HVAC display, tried disconnecting it anyway. It reads 69 degrees when disconnected but the A/C still didn't come on.
If I push the A/C button for manual A/C it turns on for a second then turns off.
Pulled both fuses for HVAC control, verified that HVAC was not functional. Waited 10 minutes and plugged in. No change. Pulled fuses for 12 hours with same result.
I also tried covering the sun sensor on the dashboard with no change. Does this need to be covered for some amount of time before it affects the HVAC system?
I haven't tried disconnecting the battery, anyone think this will have better results?
Any other ideas would be appreciated
Bill
Old Feb 13, 2007 | 06:15 PM
EHS's Avatar
EHS
Set the temperature for 70 degress.
Car is running.
After you push the "Off" button, then do nothing except push the "Auto" button.
What happens?
Old Feb 14, 2007 | 12:45 PM
randomus's Avatar
randomus
With the car running I turned off the HVAC, set the control to 70 and then pressed Auto. It immediately went to fresh air with the fan on, A/C light did not come on. Ext air temp was 56 on the display (I'm pretty sure its not that cold outside).
I also tried other temps and below 70 it would turn on the fresh air, above 70 it would turn on the recirculate. No temp would even blink the A/C light
Thanks again
Old Feb 14, 2007 | 03:43 PM
EHS's Avatar
EHS
I wish I could help you more.
I did a search, came up with nothing.
Can you tell if the compressor is kicking in when you push Off/Auto?
Rpm drops, for example?
You've checked all the belts?
Sorry I can't help more.
Old Feb 14, 2007 | 06:20 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
I was thinking AC compressor also. Its belt is seperate from all the other accessories. You could have thrown it and never known.
Old Feb 15, 2007 | 11:58 AM
randomus's Avatar
randomus
I checked the compressor belt and its definately there and turning the pulling on the compressor. I can't tell if the compressor is trying to come on. The strange thing is that the A/C light comes on in the morning during defrost.
Thanks for the help
Old Feb 15, 2007 | 01:24 PM
EHS's Avatar
EHS
Watch the tach as you push push Auto from Off. Do the rpms monetarily drop a couple of hundred rpm?
Old Feb 15, 2007 | 01:48 PM
DashingDaryl's Avatar
DashingDaryl
My guess would be that you are low on refigerant in your a/c System. It may be a small leak, or more likey as the weather heats up, the gas will expand slightly and meet the minimum pressure requirements.
Old Feb 15, 2007 | 03:16 PM
dpd's Avatar
dpd
, low refrigerant
Old Feb 15, 2007 | 03:25 PM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
Default Ac
Thanks again
It comes on when you use the defroster because the unit is designed to take out any moisture inside the car so the windows don't fog up. I don't think the AC is going to come on if the outside temperature is 56degrees and you have it set at 70 degrees. I could be wrong....
Old Feb 15, 2007 | 04:31 PM
randomus's Avatar
randomus
The tach does not move turning the system on or off during idle. It also doesn't move when I press the manual A/C button.
What's the easiest way to check the refrigerant level?
Old Feb 15, 2007 | 11:03 PM
DashingDaryl
What year do you have? If you have a car with R-134A you can go to the Auto Parts Store (Or Walmart) and get a A/C Pressure Guage and a can of refrigerant. You want to make sure the can is attached to the guage so you don't let any frigerant out or air into your system. If you get air into your system you will hose your a/c Compressor (The mosture freezes and tears up the inside)
The Guage will tell you how much or possibly if the pressure is within "Range"
Don't over do the refrigerant. If you get too much pressure your system will also shut down.
Technically there is an ambient temperature chart to figure out how much to add, but it is just easier to meet the minimum pressure when it is 80 degrees outside, and go a little higher on the guage when it gets hotter.
If you have a 98 or older (**** I THINK ***) you have Freon (R-12) which needs to be serviced by a licensed proffesional. (Or someone with an R-12 Guage.
Old Feb 15, 2007 | 11:09 PM
DashingDaryl
Old Feb 16, 2007 | 12:49 AM
EHS's Avatar
EHS
Yes. In Auto mode, A/C is always on, down to about 30 degrees. OM has the exact number.
Old Feb 16, 2007 | 01:37 AM
Scubanme's Avatar
Scubanme
I had a similar problem and it was a broken shaft on the compressor that you could not see until you removed the compressor.
To Help with strange A/C problem, please!
