Blackwing re-oiling question
Old Feb 13, 2007 | 06:03 PM
Iron Maiden Fan's Avatar
Iron Maiden Fan
Default Blackwing re-oiling question
(re-post from another section)
I've just cleaned and am re-oiling the blackwing with a factory "re-charge kit".
My main questions are:
1. How many re-oilings is the "re-charge" kit oil can supposed to have? It seems to me it would be a constant, since you start with a dry, clean filter.
2. How much oil is too much?
Any feedback would be appreciated.
Old Feb 13, 2007 | 06:06 PM
EHS's Avatar
EHS
Follow the directions on the kit.
Less oil is more. Couple of light passes. Don't over oil.
Should last for about 1.85 re-oilings, if it's the same kit that I have.
Don't over oil.
Don't over oil.
Don't over oil.
Old Feb 13, 2007 | 06:28 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
A good way to tell is if you just kind of look at the pleats and "re-color" them uniformly if that makes any sense.........
Old Feb 13, 2007 | 07:00 PM
robert123's Avatar
robert123
If the oil is dripping off the filter, you over oiled it. Some oils have a red dye to make sure you covered the whole filter.
Old Feb 13, 2007 | 07:55 PM
Iron Maiden Fan
The oil comes out like silly string, not a mist. Hard to get coverage without lots of oil on filter. Intstructions are not much help. They say to cover it completely, with no white or light area without oil.
Anyone used the kit? How did you use the oil?
Old Feb 13, 2007 | 08:02 PM
hotwheels57's Avatar
hotwheels57
The oil will "wick" through the filter media, so don't over do it. That's another reason to let it sit for a while before re-installing the filter.
Old Feb 13, 2007 | 08:11 PM
VETTING's Avatar
VETTING
Old Feb 13, 2007 | 09:45 PM
LoneStarFRC's Avatar
LoneStarFRC
Also, I do wish they would come up with a better sprayer that gives more of a "fan" pattern instead of the stream pattern it spits out.
Old Feb 13, 2007 | 10:10 PM
EHS's Avatar
EHS
Jesus Christ, it's not that complicated.
Oil it, smear it around, don't have it drip.
That's it.
If you're not comfortable doing it, take it and the filter to the guy you bought it from -- have them do it.
Old Feb 13, 2007 | 10:17 PM
LoneStarFRC
That's it.
Miss your roughage today did ya?
Old Feb 13, 2007 | 10:34 PM
Iron Maiden Fan
That's it.
It should be "one re-charge kit=1 recharge" If you need more/less oil, you did it wrong. Makes more sense to me. These filters go years between cleanings. Who wants to keep up with 1/2 can or so of oil when the whole kit is only $20! ...and how hard can it be to put a nozzles on it that SPRAYS????
BTW, i've used about 3/4 or so of the oil if that helps anyone to help me.
Old Feb 13, 2007 | 10:40 PM
Iron Maiden Fan
That's it.
...oh yeah, and hope the MAF sensor is "o.k." with the extra oil, right? It's not like tire pressure, or aiming headlights. Too much or too little gives serious problems.
Old Feb 13, 2007 | 10:48 PM
USA C5's Avatar
USA C5
Default Paper Towels
Rap the newly oiled filter in paper towels until the oil stops wicking onto the towels. I suggest you do this inside and out. Change as necessary. Next time use a syringe with about a 20g needle on it to apply the oil. Watch and observe a little dab will do yah.
Old Feb 13, 2007 | 11:37 PM
Iron Maiden Fan
Good idea! What I've been doing is stuffing the insides of the Blackwing with paper towels, then using a low pressure air compressor, blowing into the filter. I've gotten a light spatter pattern that way. Maybe doing that once a day for a few days will get any excess off.
Old Feb 14, 2007 | 04:33 PM
Iron Maiden Fan
Old Feb 14, 2007 | 04:48 PM
EHS's Avatar
EHS
Problem?
Old Feb 14, 2007 | 04:49 PM
EHS's Avatar
EHS
See post #2 above.
To Blackwing re-oiling question
Old Feb 14, 2007 | 05:01 PM
LoneStarFRC
Problem?
Nope. It was prompted by your reference to the Almighty. Lighten up.
Old Feb 14, 2007 | 05:10 PM
PilotofCorvette's Avatar
PilotofCorvette
Yes problem, the guy is asking for advice and you have to jump on him.
Try staying out of the cold.
Ha Ha
Old Feb 14, 2007 | 08:52 PM
EHS's Avatar
EHS
Ha Ha
I understand, and I gave the advice already in post #2.
I guess by post #9 I was getting a little frustrated. Sorry.
Between the early posts, and the instructions, it's a fairly straight forward process.
The instructions are very, very detailed, and very, very self-explanatory.
And very, very simple:
Step 1
Step 2
Step 3
Step 4
