help, headlights flicker & work inconsistent
Old Feb 15, 2007 | 09:06 AM
gwood's Avatar
gwood
Default help, headlights flicker & work inconsistent
2 problems, maybe related, maybe not, on my 2000 coupe. (1) slight headlight flicker whenever I use turnsignal or hit brake lights. (2) Sometimes headlights won't open. Inconsistent, but sometimes I have to shut the car off, then turn on the headlights, then start the car again. Any ideas? thanks...
Old Feb 15, 2007 | 10:55 AM
Sully1882's Avatar
Sully1882
Default grounds
you need to review Bill Curlee's sticky on electrical info. I would be willinng to bet you are havinng problems with corrosion in the ground packs....there's tons of info and it is an easy thing to correct! Good luck.
Sully
Old Feb 15, 2007 | 04:18 PM
csr81's Avatar
csr81
1st Gear
Default Tighten battery terminals
I had a similiar problem on my 99 FRC. Car went completely dead while getting gas one day, which clued me in to the battery terminals. Once these were tightened all of my electrical gremlins seemed to vanish. Watch your volts on the DIC. I bet they are bouncing around quite a bit. After tightening battery terminals my DIC volts are rock steady, usually around 14.2. Hope this helps.
To help, headlights flicker & work inconsistent
