New Valve seals too?
Old Feb 17, 2007 | 11:09 AM
72Shark's Avatar
72Shark
Default New Valve seals too?
I'm installing a new cam, valve springs, retainers, and pushrods. Do I need to install new valve seals too? I have a 2002 Z06, with 13K miles. Saw somewhere (cant remember where) where it is recommended to install new "brown" exhaust valve seals on all 16valves. (If so, where is the best place to purchase these???) Thanks.
Old Feb 17, 2007 | 11:52 AM
FRCTony's Avatar
FRCTony
The valve springs you use will dictate whether they need to be replaced.
I would ask the vendor. Many spring kits come with new seals.
Old Feb 17, 2007 | 11:56 AM
vettenuts's Avatar
vettenuts
If you go with beehive springs, no. If duals, not only do you need new seals but they must also be the older design.
Old Feb 17, 2007 | 12:17 PM
72Shark's Avatar
72Shark
Springs are Comp 918's.
Old Feb 17, 2007 | 12:21 PM
FRCTony's Avatar
FRCTony
No seal replacement required for those. I'd keep what you have
Old Feb 17, 2007 | 12:29 PM
72Shark's Avatar
72Shark
Awesome! Thanks.
Old Feb 17, 2007 | 12:37 PM
vettenuts's Avatar
vettenuts
Yep, should make for an easy swap. If you don't have a tool yet, the Crane/VHP tool is the best I have seen.
To New Valve seals too?
