Rust on rotors?
Old Feb 20, 2007 | 10:53 AM
LTVetteVert00's Avatar
LTVetteVert00
Default Rust on rotors?
I think I saw this on CF before...but cannot seem to locate it now?
I got caught in the rain and now my shiney, bling bling rotors have an ugly, Saturn ring of rust at the outer edges.
I presume I need to pull the wheels and clean them with something...what? Fine steel wool?
Help...advice...sympathy?
Old Feb 20, 2007 | 11:07 AM
B-rent's Avatar
B-rent
Old Feb 20, 2007 | 11:10 AM
2000BSME's Avatar
2000BSME
don't be such a nancy boy
Old Feb 20, 2007 | 11:19 AM
SilvaDragon's Avatar
SilvaDragon
Use a fine emery cloth, like 200 grit. Work from the bottom edge,
and use spray Brake Cleaner (nothing else, only Brake Cleaner),
to wash down the dust and grit from the emery cloth so it doesn't
get under the brake pads. Put a catch bucket under the rotor to
catch the dust and runoff. It's OK if brake cleaner gets on pads,
just don't soak them.
Old Feb 20, 2007 | 11:35 AM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
if you don't have access to a sand/bead blaster, be sure to mask off the area of the rotor that the pads seat on, then i use a wire brush on the hat area and the center section between the surfaces the pads ride on. i use compressed air to blow away the rust, tape off the surfaces that the pads ride on, you can see a fine circle where the pads stop and cut the tape there, then paint the color of your choice.
Old Feb 20, 2007 | 11:51 AM
jon c's Avatar
jon c
if they arent zinc coated they are just going to rust again in the very near future....
Old Feb 20, 2007 | 12:14 PM
robvuk's Avatar
robvuk
Can you say "obsessive compulsive".
Old Feb 20, 2007 | 12:16 PM
LTVetteVert00
Yes...I might even be able to spell it. I guess it comes form seeing all these cool pix on the Forum and not a one of them appears to have rust??? Pooh!
Old Feb 20, 2007 | 12:57 PM
Wah's Avatar
Wah
Whoa.
You got your Corvette rained on and all you care about is some rust on the rotors ?!?
GET THAT THING REPAINTED !
Old Feb 20, 2007 | 01:12 PM
robert123's Avatar
robert123
sand them, they will rust in 2 or 3 days. Live with it.
Old Feb 20, 2007 | 01:15 PM
If they are not zinc coated, short of painting them, they will rust again. You can paint the hats and vent hole area and it will look good for quite a while.
Old Feb 20, 2007 | 01:25 PM
C6NRED's Avatar
C6NRED
What? You want yours to look like this?
5,000 miles, and I've never had to touch them..........
Old Feb 20, 2007 | 01:34 PM
LTVetteVert00
Default That's It...!
Perfect example.....now, how did you do that??????
Old Feb 20, 2007 | 01:45 PM
EHS's Avatar
EHS
... 5,000 miles, and I've never had to touch them..........
5,000 miles? WOW!
I've got 78,000 on mine and haven't touched them either.
Old Feb 20, 2007 | 02:18 PM
Sleazy Rider
on my 89', i blasted the rotors and painted them and the brackets about 3 years ago. they still look good and no rust anywhere. i just did the same with my 03' Z 2 weeks ago.
Old Feb 20, 2007 | 03:00 PM
robvuk's Avatar
robvuk
Now there is a perfect example of someone who spends more time waxing than driving.
Old Feb 20, 2007 | 04:19 PM
C6NRED's Avatar
C6NRED
Actually (I posted the pictures of the rotors above....) I've never touched those rotors since putting them on....I bought them on eBay (Grip Force F1's) for only about $180.00 for all four. They are zinc coated and have stayed looking just like they do for the last 5K miles....that said, I would never consider racing with these or autoxing...I know what I bought and for the price, I have been happy with their looks and performance on the street............
To Rust on rotors?
