when i am going between 70 and 80 at a steady speed, it feels like my overdrive will engage then disengage and i can see a 2 to 3 thousand rpm jump when it happens any suggestions?
I had a similar issue with a different car. The radiator thermostat was sticking open so the car was not getting up to temp in cooler weather thus the tranny was staying in a higher gear. The transmission shop looked at it and told me to change the thermostat. I did and it cleared up and shifted properly.
I don't have my manual with me at this moment or it may say something about transmission fluid temp also.
Thus:
monitor you transmission fluid level (though I am not sure if the OD is fluid controlled), monitor the transmission fluid temp in the dic screen during the occurence,
Your Converter Is Unlocking Then Locking Back Up.
Is It Real Windy Or On Hills ? If Not And The Converter Keeps Unlocking When Your At A Steady Mph In 4th.... Your Converter Or Lockup Solenoid Is Going Bad
i would check trans fluid level and condition, i just had trans service done recently at dealer, got car back and noticed trans shifted wierd in/out of overdrive and when i punched it could not go over 80 would bog out, took back to dealer found transmission fluid 1 1/2 qt low. p/u car test drove home and now it shifts great and goes into over drive
thanks for the reponse i filled my trans fluid. and it does it too in cruise even after the trans fill it is still doing it after the fluid warms up. the only mods i have is an exaust.
