Patriot Heads
Thanks,
SLPRC5
I will be going with a head and cam combo from LAPD which will net 405 RWHP "Proven" combo on an '98 A4 w/3.15's.
Thanks,Matt
Compare them to stock heads, the fist column is LS6 and the second column is Ls1:
.1 == 64/52.5 --------- 63.5/52.9
,2 == 135.8/103.8------ 137.8/97.8
.3 == 195.2/135.4 ----- 196.0/129.7
.4 == 236.9/157.1 ----- 214.5/158.0
.5 == 260.0/169.4 ----- 223.5/169.9
.6 == 260.0/179.9 ----- 233.3/180.0
.650 = 260.5/183.0 ---- 237.2/183.2
You can also compare them to the Flow numbers of my heads on AFR's flow bench with a 3.9" bore and the exhaust through a 1.875" pipe:
Int. @ 28" on a 3.900 bore
.200....146
.300....208
.400....252
.500....283
.550....293
.600....298
Exh. @ 28" with a 1.875 pipe (3.900 bore obviously)
.200....117
.300....174
.400....209
.500....225
.600....235
Hammer
The only thing to really top them is TFS, but they are in a whole different price range.
.200....146
.300....208
.400....252
.500....283
.550....293
.600....298
.200....117
.300....174
.400....209
.500....225
.600....235
Hammer
SLPRC5
Thanks,Matt
I have a 224/224 567/.567 lift cam installed and these heads to go with it.
I have a 3:42 rear...A4..so my goal of 400 RWHP is reachable.
Thanks for your input.
SLPRC5
.200....146
.300....208
.400....252
.500....283
.550....293
.600....298
.200....117
.300....174
.400....209
.500....225
.600....235
Hammer
What I haven't been able to find is the HP difference between the pricy heads vs the ported LS6 heads available for a given moderate cam. Is it 5-10 HP or more? What would one get for the $1000 price of a more expensive head?
[/QUOTE]I'm hoping these heads will put down 20 to 30 more HP.
I'll know for sure after they are installed and a dyno is done.
I'm switching from stock 2003 LS6 heads to the Patriots. The cam is a 224/224 .567/.567 lift LSA 114
