Cam replacement 00 FRC
Old Feb 21, 2007 | 04:28 AM
POK868's Avatar
POK868
Default Cam replacement 00 FRC
I want to get a new cam and underdrive pulley put on my 2000 FRC, anyone know a reasonable/reliable place to get this done in central/north jersey. Got a quote from Cartek in Garwood they wanted 3200 including parts/labor, cam was like 500, pulley and belts like 300 so it looks like 2400 or so in labor seemed high to me. If anyone has a recomendation on where to go please let me know I am thinking that 800-1000 is a more appropriate charge for this service. Thanks,
Jon
Old Feb 21, 2007 | 05:03 AM
vettenuts's Avatar
vettenuts
Contact Steve (CTCorvette). He is in Avon, CT but from his posts he appears to be very consciecious in his work and is ex-Air Force so based on my dad's methods of working on motors, he is probably careful as all heck too.
Old Feb 21, 2007 | 06:34 AM
LKGRenegade22's Avatar
LKGRenegade22
I can't help you with a place to get it done but I paid $1K for a cam swap on my car and you can do the pulley while installing the cam so that shouldn't be anymore. They probably added in $500 or so for a tune though, even though that would still only be $1500?
Old Feb 21, 2007 | 01:01 PM
POK868's Avatar
POK868
bump
Old Feb 21, 2007 | 02:35 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
If distance is a concern, then you could try TTP Performance in Clifton.
I however recommend ECS. Farther drive but well worth it. They are one of the best in the nation..whats an extra hour drive?
Oh and a cam swap will need a dyno tune, valvetrain upgrade such as valve springs, retainers, locks, etc. ...that is why you need to budget more than 1000
Old Feb 21, 2007 | 03:04 PM
94legaleagle's Avatar
94legaleagle
Are you talking about an aftermarket performance cam, or are you talking about replacing a stock cam w/ a stock cam?
Old Feb 21, 2007 | 04:27 PM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default ECS works for me!!
ECS did the tune on my '00 FRC. I was very happy with the results!!.
I don't remember ever hearing any complaints about them.
Bob K.
Old Feb 21, 2007 | 04:54 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Feel free to give us a call if you have any questions at all..
609-752-0321
__________________
Home of the Fastest Supercharged C5 8.4 @ 158mph
Home of the Fastest Supercharged IRS GTO 9.0@ 155
Home of the Fastest Supercharged C6 9.7 @ 143mph
Proud Sponsor of the ECS Corvette Challenge
http://www.corvettechallenge.info
609-752-0321
Old Feb 21, 2007 | 06:12 PM
Vette-Red's Avatar
Vette-Red
$3200 is way to high for that; sounds like someone is making a tremendous amount of money on that deal. I think my friend paid around $1300 for the cam and supporting hardware installed at MTI.
Old Feb 21, 2007 | 08:16 PM
Dave_Busch's Avatar
Dave_Busch
Jon
Jon,
You left out a few items. Here is a list of what we would be doing.
Parts,
Cartek Custom ground cam, computer verified before installation.
Manley dual valve springs.
Titanium retainers.
Spring seat locators.
Viton valve seals.
Spring shims.
HD cam bolts.
Cromoly push rods.
Double roller timing chain with torrington thrust bearing.
ASP under drive pulley.
AC and main serpentine belts.
Front cover gasket.
Front main seal.
6 quarts of oil and an oil filter.
2 gallons of Dexcool coolant.
Labor and services,
All labor to, install the valve springs at the correct height, install and degree the cam, measure the push rods for the correct preload, all other necessary labor.
Full custom dyno tuning.
The cost of going faster with just a cam than others have gone with heads and cam = priceless.
Old Feb 21, 2007 | 08:34 PM
KapUSMC's Avatar
KapUSMC
I've been west coast and midwest... So I don't know the tuner's on the east coast other then by reputation. But the only advice I would give is shell out a little extra to go to one of the premier tuners... Esp for the tune. You'd be amazed how they seam to get more power out of the exact same setup.
Old Feb 21, 2007 | 08:42 PM
Max@Cartek's Avatar
Max@Cartek
Shops use different manufacturers for different parts such as springs, retainers, etc. These parts vary in price and quality.
What you are looking for is results and quality. Yes price does factor in, but so does results. When we design a package for a customer we ask many questions to tailor the package for the driveabilty and performance you are looking for. We've spent hundreds of hours on the dyno and the track testing combinations for optimal performance, durability, and driveabilty.
While most shops install a cam in one day the same job takes us two and a half days because quality and optimum performance can't be rushed.
Max
Old Feb 21, 2007 | 11:28 PM
POK868's Avatar
POK868
Jon/Dave, thanks for the additional information, I didnt realize all the additional pieces in your price. I have a bit of a conundrum to figure out, I need to replace the pulley as it is wobbly while there I was thinking might as well do the cam......I have to figure this one out
Old Feb 22, 2007 | 08:55 AM
Dave_Busch's Avatar
Dave_Busch
Anytime Jon, that is what we're here for. Changing the pulley or also installing the cam, either way we would be happy to help. The pulley will net 7 RWHP by it's self, and the cam an additional 35 to 40.
To Cam replacement 00 FRC
