Common maintenance items
Old Oct 8, 2001 | 01:05 AM
PaulJ's Avatar
PaulJ
Default Common maintenance items
Here is a list of mileages and maintenance items I've put together. Comments?
Every 6 months, apply dielectric silicone grease to weatherstrips GM 12345579, Ecklers A2524 ($23.95 -10%), http://www.mcmaster.com/ search for Krytox
Every 12 months, apply “Multi-purpose Lubricant Superlube” to key lock cylinders, hood and door hinges
Every 12 months, apply “Lubriplate Lubricant Aerosol” to latches
Every 36 months, coolant
Every 30k miles, replace air filter (ACDelco A917C), spark plugs
Every 50k miles, change ATF (DEXRON III) and filter
Engine oil Mobil 1 10W-30, Red Line Oil 10W-30, 6 quarts
Engine oil filter ACDelco UPF44, Pep Boys
Air filter ACDelco A917C
Brake fluid ACDelco Supreme 11 (DOT3) GM 12377967
Automatic transmission filter ACDelco TF306
Automatic transmission fluid DEXRON -III ATF or Red Line Oil D4 Synthetic ATF, 5 quarts
Rear axle, SAE 75W-90 Synthetic Axle Lubricant GM 12378261, 1.7 quarts, GM Axle Lubricant Friction Modifier PN 1052358, 4 ounces -or- Red Line 75W80 Lightweight Synthetic Gear Oil, 1.7 quarts
Coolant Surge Tank Cap GM 10296465
PCV valve ACDelco(?) 799C
Spark plug ACDelco(?) 41-931
Thermostat GM 12555717
Key lock cylinders, hood and door hinges GM 12346241
Hood latch Lubriplate lubricant aerosol GM 12346293
Wiper blade 22 inches with 9 mm x 13 mm Shepherd’s hook, factory wiper blades are Trico's and available at Pep Boys or GM part# 10418003
Fuel tank cap ?
Fuel filter GM 10299164? AC Delco GF820
Accessory drive belt ?
Coolant 50/50 GM DEX-COOL
Power steering GM 1052884 (1 pint) or GM 1050017 (1 quart)
Weatherstrip Dielectric Silicone Grease GM 12345579 or Krytox (http://www.mcmaster.com/)
Red Line Oil - http://www.redlineoilracing.com/ or Dave Turner Motorsports · San Diego, CA · 619-571-3811
Performance GM rotors, left 12480155, right 12480156
Old Oct 8, 2001 | 08:18 AM
99 Torch Coupe's Avatar
99 Torch Coupe
Default Re: Common maintenance items (PaulJ)
The two part numbers you didn't have
Belt 12561501
Fuel Cap 22616286 superseeded to 22660003
Old Oct 8, 2001 | 02:04 PM
carpe dm's Avatar
carpe dm
Good list, but I would change the entire air filter assembly on day 1, and I would list the oil required as 61/2 quarts. Some swear they take 7.... :rolleyes:
Old Oct 8, 2001 | 02:25 PM
cruzin''s Avatar
cruzin'
I believe the coolant in current GM vehicles is good for 100,000 miles. It should be the red/orange Dexcool II stuff.
Old Oct 8, 2001 | 09:38 PM
RadarBlue's Avatar
RadarBlue
Coolant - replace every 150,000 Mi or 60 months
Spark plugs - replace every 100,000 Mi
Did you want to include belts?
A/C compressor - P/N 12556609
Serpentine - P/N 12561450
Old Oct 10, 2001 | 10:06 AM
MarkSee5's Avatar
MarkSee5
Default Re: Common maintenance items (RadarBlue)
How many quarts of 50/50 antifreeze/water does my '97 take? And I should be able to use the DEX Cool II stuff right? Thanks for answering a stupid question.
Mark
To Common maintenance items
