header install leaking questions.......
Old Feb 21, 2007 | 09:34 PM
02gt350's Avatar
02gt350
Default header install leaking questions.......
they are not on the car yet, but there seems to be a lot of play between the x-pipe and the header. They just slide on. Once they are together, there is just way to much play and i can tell it will leak. Does anyone else have this problem? do you all just use the sleave clamp?
Old Feb 21, 2007 | 10:12 PM
LoneStarFRC's Avatar
LoneStarFRC
Hard to say since you never said what brand you're dealing with. The Kooks headers I've been using use a "ball-socket" type connection instead of the older design "flat" flange and don't use a gasket at all. Some other brands use this design as well. I've had zero header leaks ever since my install a couple years ago.
Old Feb 21, 2007 | 11:02 PM
jeanlucpicard's Avatar
jeanlucpicard
If your exhaust system / headers have the slip fit there will be clamps that go on the slip fits to tighten up the joint. I also have Kooks and the x-pipe section uses a slip fit - no leaks if you tighten the clamps.
Some Forum members have used a high temperature RTV to help seal the slip fit joint but I would not want to have to deal with the RTV should you need to pull the pipes apart - and you will when the starter fails.
Good luck.
Old Feb 21, 2007 | 11:07 PM
02gt350's Avatar
02gt350
sorry, they are the TPIS slip fit. It just seems like the clamp will not tighten enough. What type of header wrap could be used?
Old Feb 21, 2007 | 11:49 PM
dudleyd's Avatar
dudleyd
For slip fit exuast joints the best clamp IMHO is the TorcTite step clamp.
http://www.torcausa.com/Torctite.htm
Old Feb 22, 2007 | 08:19 AM
vettenuts's Avatar
vettenuts
That's what I used and they are high quality clamps and work great.
Old Feb 22, 2007 | 09:18 AM
Dave_Busch's Avatar
Dave_Busch
Yup that's what we use. They will work great, and no RTV will be needed.
Old Feb 22, 2007 | 09:27 AM
02gt350's Avatar
02gt350
this is what you used at the collector?
Old Feb 22, 2007 | 10:29 AM
BudgetPlan1's Avatar
BudgetPlan1
St. Jude Donor '09-'10
yep, collector to cat on lg pros
To header install leaking questions.......
