Swaping gears Question.
Old Feb 22, 2007 | 11:01 PM
jeff49's Avatar
jeff49
Default Swaping gears Question.
I want to go to 342s from 315s.Can I Just swap out the gears or change the whole rear end thanks for the info. jeff
Old Feb 23, 2007 | 04:26 AM
Blown 346's Avatar
Blown 346
You could just swap the gearing.
Old Feb 23, 2007 | 08:33 AM
oldschoolvette's Avatar
oldschoolvette
replacing the entire unit or rebuilding it w/new gears either way will work. replacing the entire differential might be cheaper
Old Feb 23, 2007 | 09:55 AM
waupachino's Avatar
waupachino
Check out this thread. http://forums.corvetteforum.com/show....php?t=1629922 Looks like Cajundude is doing this now and it seems like a very good deal. I would almost bet he would probably even have a set of used 3.42 gears he swapped out for someone going to a higher ratio. Worth a try either way.
To Swaping gears Question.
