Vibration help
Old Feb 25, 2007 | 12:27 PM
sugarwolf's Avatar
sugarwolf
Default Vibration help
Ok the other day my clutch wouldnt release right and wouldnt go into gear ect. So i pulled the clutch cover and behold loose pressure plate bolts. Before i had no vibration, now since i tightend the bolts it vibrates at idle and at 2500 and above. Its a Z06 clutch i have. So did the loose bolts warp the flywheel or somthing? Will a new clutch fix this problem?
