Question about DECARB
Old Feb 26, 2007 | 12:59 PM
DADEO1's Avatar
DADEO1
Default Question about DECARB
This may seem a dumb question but ...
Does the decarb process seem to help with piston slap.
Mine like many is a slapper until it warms up.
I am sure I could use a decarb, just wondering.
Old Feb 26, 2007 | 04:17 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Nope, decarb will make it run smoother.
www.pistonslap.com
Old Feb 26, 2007 | 07:24 PM
TopFuelTim's Avatar
TopFuelTim
Default What method do you use to decarb
I've heard people talk about Seafoam something, but I wonder what the best method to do this is?
Is it simply unplug the brake booster vacuum line and add the stuff? Is it a liquid or a spray? Does anyone have pics? Is there a specific Seafoam product to ask for?
Mine also slaps pretty hard, and I can even hear it slapping a little when the engine is warmed up. I too was wondering today if decarbing it would help lower the noise, but I think it needs it done anyway, as I am hearing some part throttle detonation, even using Texaco 93 octane.
Thanks,
Tim Glover
Old Feb 26, 2007 | 09:18 PM
cruisemon's Avatar
cruisemon
Thanks,
Tim Glover
Except to the extent decarbing will remove deposits that may cause preignition, decarbing has no effect on piston slap, a phenomenon observed normally at startup in relatively cold ambient temperature. My '98 exhibits slap for a few seconds after start up in ambient temperatures below about 35 degrees. As soon as the engine begins to warm up it goes away. Just don't romp on it hard at startup and the engine will last longer. I had a '91 that I bought with 68,000 miles on it and drove it to 104,000. The pistons slapped when I bought it and the rear end clunked on downshift (A4) as well. It was still doing both when I sold it and had never showed signs of crapping out.
Charlie
Old Feb 27, 2007 | 09:09 AM
DADEO1's Avatar
DADEO1
Thanks,
Tim Glover
There are quite a few threads on this subject.
One was on yesterday in a lot of detail.
Most are using Seafoam you can get it at NAPA, Auto Zone, any auto supply should have it.
There are two types although I have only seen one.
Regular Seafoam and SeaFoam deep creep.
Take a vacum hose loose and stick the hose in the can and suck it in.
Let it sit, I would think like overnight.
Start it up and watch it smoke until clears up.
Probably a good idea to change the oil after the decarb.
Sounds simple,
Old Feb 27, 2007 | 06:25 PM
TopFuelTim's Avatar
TopFuelTim
Default Thank you!
I didn't catch on about letting it sit overnight. Will do some more searches on Seafoam before I do this. Oil is around 80% right now, so I guess I can wait a couple of months.
Thanks,
Tim Glover
To Question about DECARB
