Spark Plug Removal.....HELP!!!
Old Feb 26, 2007 | 09:49 PM
BATM4N's Avatar
BATM4N
Default Spark Plug Removal.....HELP!!!
I think I'm big trouble I bought some NGK 55's and tried to get off the #1 and #4 on the passengers side. I tried with all my might(or at least with whatever leverage I could get) and didn't budge at all.
I haven't removed spark plugs since my college days but don't remember it being this difficult. Tried with engine cold. I've read here before to use some sort of "anti-seige" but can't even see where the threads are for the spark plug All those with spark plug knowledge please chime in.
Old Feb 26, 2007 | 09:58 PM
Tigershark3's Avatar
Tigershark3
You're right trying to remove them on a cold motor.... Remember - lefty loosy and righty tighty. Having said that, I know there's not a lot of room to work but you might try some WD40 or penatrating oil, wait a few hours they have at them again. $.02
Old Feb 26, 2007 | 10:07 PM
az57chevy's Avatar
az57chevy
When did you last change them?
Old Feb 26, 2007 | 10:10 PM
BATM4N's Avatar
BATM4N
The car has 90K and I think these are the original spark plugs....why do I think this??? Because I can't get one off to see if it's an original spark plug!!!!
Old Feb 26, 2007 | 10:13 PM
BATM4N's Avatar
BATM4N
Originally Posted by Tigershark3
Remember - lefty loosy and righty tighty..try some WD40 or penatrating oil, wait a few hours they have at them again. $.02
O.K. glad to hear at least I was pulling the correct way. I'll try to put some W.D.40 and see what happens.
brucemoose2's Avatar
brucemoose2
I think you mean to say "anti-seize". You can get it at the autoparts store where you bought the plugs. You should apply that to the threads of the new plugs, before you install them. You only need a very small dab on the threads - keep it off the electrode.
As for getting the old ones out, try some penetrating oil as the others have recommended. WD40 is not the best choice, but PB Blaster or something similar would be fine.
Old Feb 26, 2007 | 10:21 PM
BATM4N's Avatar
BATM4N
I've never heard of that but will assume you can get it at any auto parts store. At this point I'll try anything you guys suggest.
Old Feb 27, 2007 | 01:33 AM
jbauch357's Avatar
jbauch357
There have been times I would have given my left nut for a can of PB Blaster - that stuff is awesome!!!
Old Feb 27, 2007 | 01:44 AM
AtHomeSoda's Avatar
AtHomeSoda
Default Do Not Force It
Get a bigger wrench.....
Old Feb 27, 2007 | 01:45 AM
Blown-Interceptor's Avatar
Blown-Interceptor
I am local, let me know if I can help you out?
Jason
Old Feb 27, 2007 | 02:09 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
It's a pretty common problem with platunum plugs--people don't change them for 100k miles and they seize onto the head--It's a good idea to still remove and inspect the platinums once a year regaurdless and apply anti-seize so it won't happen again---
Old Feb 27, 2007 | 03:28 AM
LKGRenegade22's Avatar
LKGRenegade22
Get you a can of PB blaster from the auto parts store and srpay it on there. After that has sat awhile if the plug won't come out something is seriously wrong. Do use a big ratchet though.
Old Feb 27, 2007 | 07:04 AM
VinnyT's Avatar
VinnyT
Cheater bar!! Or a piece of pipe. That's what I used. Mine were pretty tight @ 50K miles. Just slowly apply torque to the bar. It will come loose.
Old Feb 27, 2007 | 08:41 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Platinum plugs have nothing to do with this, the only platinum on the plug is a microscopic chip on the electrode.
Old Feb 27, 2007 | 08:59 AM
Bill Dearborn's Avatar
Bill Dearborn
I think he was implying that platinum plugs are left in longer and therefore have a greater tendency to seize to the head.
Bill
Old Feb 27, 2007 | 09:53 AM
in2fun's Avatar
in2fun
I too just had this problem last week when I did mine at 60,000. It was a $%$!*& to get them off. I had to use a cheater bar also. I also used a socket wrench that could split in 2 places. I used a pipe over the wrench, but did not have much room to work with on the drivers side of the engine so I could only turn the wrench a little at a time. Sears sells a cheater bar that's 16 to 18 in. that can be used in place of the wrench to at least break them loose, then go back to the wrench to finish getting them out. Just make shure you don't force the new plugs back in. If there not in the threads just right you could strip the threads. I use a rubber fuel or vacuum tubeing hose to fit just on the tip of the plug and use that to set the plugs in place. Make shure you have a tight fit on the plugs with the tubeing and just give it some turns with the tubeing untill they set, then just pull the tubeing off and finish with the wrench. Good luck !
in2fun
Old Feb 27, 2007 | 10:46 AM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Bill
Platinum plugs are supposed to be good for 100k so people leave them in way too long.
I just helped my buddy Vinny change the plugs on his "new" '99 FRC w/ 55k that had factory everything.
The plug wires were mostly fused on and had to break 2 of them to even get them off. The plugs broke loose w/ an audible "click" as they were pretty well fused into the heads.
Had to get a cheater bart to slip over the rachet a few times for more leverage.
When re-installing dab some anti-seize on the threads of the new plugs. I've always done this and have no issues changing plugs every 20k or so. I use NGK TR-55s.
To Spark Plug Removal.....HELP!!!
Old Feb 27, 2007 | 11:08 AM
berryj's Avatar
berryj
I had to do this too. A couple of those plugs are very difficult to access. I ended up using two hinge adaptors to even be able to get a socket wrench to work. I've heard from someone that ?Sears or some other place sells a specific spark plug socket w/ hinged adaptor already attached to make this easier. Anyone know of this or where to get it/pricing? Apparently, other vetters said it made the job a whole lot easier.
Old Feb 27, 2007 | 11:14 AM
Cobra4B's Avatar
Cobra4B
^ I have no more AIR sytem so it's not an issue for me... but on cars that still have AIR it helps to unbolt the fitting from the manifold or header and move it up out of the way. Also, disconnect tha vaccum line from the brake booster and move it out of the way.
Old Feb 27, 2007 | 12:39 PM
BATM4N's Avatar
BATM4N
Jason
I appreciate that Jason I just might if I can't get some of these out.
