Spark Plug Removal.....HELP!!!
Old Feb 27, 2007 | 01:39 PM
Point & Shoot's Avatar
Point & Shoot
Here's an earlier post re changing spark plugs - the key is using a wrench with a longer handle for more leverage & taking your time. Once you have the longer wrench, slowly apply leverage and they come loose easily - make sure the socket is completely seated on the plug before trying to loosen.
I recently did mine for the first time and will pass on what I learned from experience. I hope this helps.
Parts
I used AC Delco Iridiums #91-485 $55.
I used a set of stock replacement Autolite wires for $35.
(I bought both at Advanced Auto).
Anti seize compound to put on the threads of the new plugs
Dielectric grease
Tools
5/8" Craftsman swivel socket
3 inch extension, 6 inch extension, 10 inch extension depending on location
1/2" drive Craftsman pivoting head socket wrench (21" handle) with 1/2" to 3/8" adapter
3" long piece of vacuum hose that slips over the plug insulator so you can start the threads in by hand
Mechanic gloves so you don't destroy fingers, hands, and knuckles
Helpful Hints
Change the plugs when the engine is COLD.
The rear plug on the drivers side (#7) is the hardest so get the feel of some of the easier ones before you go there.
The hardest part for me was getting the old wires off. Make sure you grab the end of the boot and yank really hard - don't worry if you destroy a wire because you have a new set.
The long handled pivoting head ratchet made the job a breeze because it gives you great control and leverage to break the plugs free & the extensions keep your hands well above the tight spots. I tried with a smaller ratchet but wasted about an hour and got frustrated as well.
Put a light coat of anti seize on the threads of the new plugs and start them in by hand as tight as you can get.
Put the socket wrench on, snug then go 1/16 of a turn.
Put some dielectric grease in both the coil end and the spark plug end of the wire and snap them on.
The total job took me 2 hours and I was taking my time.
nwdanner's Avatar
nwdanner
Originally Posted by Cobra4B
^ ...on cars that still have AIR it helps to unbolt the fitting from the manifold or header and move it up out of the way. Also, disconnect tha vaccum line from the brake booster and move it out of the way.
Old Feb 27, 2007 | 01:45 PM
Blown-Interceptor's Avatar
Blown-Interceptor
Originally Posted by captcruz
I appreciate that Jason I just might if I can't get some of these out.
No problem...let me know.
Old Feb 27, 2007 | 02:02 PM
BATM4N's Avatar
BATM4N
Thanks to all you guys for all your input on this issue. Here is where I am now: I didn't have anything last night but WD40 to help loosen them up for this morning. Even with that I couldn't get the leverage I needed so I used an old piece of electrical PCP pipe and managed to finally get the 4 passengers side ones off
Not sure how I'm going to tackle the drivers side with all the crap that is in the way but maybe someone has some keen ideas
Does anyone know by these pics whether these are the original spark plugs? Just curious
Old Feb 27, 2007 | 02:09 PM
Blown-Interceptor
Take off the air tube on the drivers side, not to bad at all change the drivers side.
Old Feb 27, 2007 | 02:24 PM
VinnyT's Avatar
VinnyT
Yeah, they look original. As others have said, tahe off the air assembly hose/coupling. It will help tremendously.
Old Feb 27, 2007 | 02:28 PM
VetteDrmr's Avatar
VetteDrmr
Changing out the plugs twice before on mine has led me to re-learn the old adage of taking some time to remove things to give yourself more room to work ends up being the fastest way to work.
Up front: you don't HAVE to do this to change out the plugs. But, I've found it makes the job much easier.
1. Disconnect the negative battery terminal
2. Pull the alternator (the reason for step #1)
3. Remove the coil packs
Now, pull the wires and AIR tube on the drivers side. You'll find the plugs much easier to get to, which gives you more leverage, etc....
My experience has been the up front work is no more than about 10 minutes (and of course 10 minutes putting stuff back together).
HTH, and have a good one,
Mike
Old Feb 27, 2007 | 03:42 PM
Dave68's Avatar
Dave68
I'd also like to add one more thing to all the good advice here:
Blast the sand and crud out and away from the plugs before you pull them out. That sand and "stuff" will find its way into the combustion chamber, so blast the stuff away from those plugs using compressed air or vacuum. My opinion is that yes, it is good to remove the OEM plugs before 100K miles, but once you apply anti-seize, you shouldn't have to remove your plugs every year. I've had greased plugs in an aluminum head for 8 years and they came out without any problem. Remember, the more often you remove plugs, the more likely sand and crud is going to get into the chamber.
Old Feb 27, 2007 | 04:14 PM
hotwheels57's Avatar
hotwheels57
Do yourself a favor and buy some more tools for your DIY jobs. While PVC is inventive, you can do the job easier with the right tools.
Old Feb 27, 2007 | 04:20 PM
BATM4N's Avatar
BATM4N
Didn't even think of that crud due to all the other stuff I had going on trying to get them out. Good advice
Old Feb 27, 2007 | 04:24 PM
craig04c5's Avatar
craig04c5
I told a friend of mine that I was going to take my plugs out and put anti seize on them and put them back (car only has 15K miles) and he asked why they don't put it on at the factory? I then wondered if they do or not? Good question in my opinion if they are saying 100K miles they should put anti seize on them when building the car. BTW I did take them out and put anti seize on them and they did not appear to have been done originally.
BATM4N's Avatar
BATM4N
No $hit Sherlock I have more tools than the average garage and never thought replacing spark plugs would be such a job. It is definitley a "right tool" type of job. I'll never attempt this again without them
Old Feb 27, 2007 | 04:36 PM
  #33
Blown-Interceptor
YES, YES and YES! Put it on, save yourself headaches like this one.
Old Feb 27, 2007 | 07:14 PM
  #34
BATM4N's Avatar
BATM4N
Mike
You've got to have headers and the right tools to be able to do it in that time
Old Feb 27, 2007 | 07:26 PM
  #35
IFLUBYU's Avatar
IFLUBYU
100k? Time for some new heads, solves all the spark plug issues! nyuk, nyuk!
Old Feb 27, 2007 | 08:02 PM
  #36
VetteDrmr's Avatar
VetteDrmr
Not the whole job, only pulling the alternator and coil packs. Only tools used are spark plug socket and typical 3/8" metric socket set.
Probably an hour (not counting dealing with tight plugs) for the whole job. Stock manifolds.
Have a good one,
Mike
Old Feb 27, 2007 | 10:20 PM
  #37
BATM4N's Avatar
BATM4N
O.K. I'm a believer I bought some PB Blaster for the drivers side and what a difference getting the drivers side off Like night and day. Now for the dreaded last two closest to the firewall Wish me luck...I'm going to need it
To Spark Plug Removal.....HELP!!!
Old Feb 27, 2007 | 10:32 PM
  #38
Blown-Interceptor
You don't need luck, just a little patience, you will get them.
Old Feb 28, 2007 | 01:12 PM
  #39
craig04c5's Avatar
craig04c5
Heck without headers it takes 20 mins to just get the fricken boots off the plugs. Then if you do it right and put die electric grease in the boots and anti seize on the plug threads you have at least 50 minutes to do them and that's if all goes right.
Old Feb 28, 2007 | 06:04 PM
  #40
brucemoose2's Avatar
brucemoose2
Glad it worked for ya. PB Blaster is good stuff. WD40 is fine for some jobs. It's NOT very good as a penetrating oil...
