I have seen alot of different setups, I can't seem to find anything that says what the largest tire/wheel combo you can fit under a stock C5 without rubbing. I am thinking of going up 1 inch in diameter, but not sure how wide I can go without rubbing...at all! Any input would greatly be appreciated.
I know people have gone wider than this, but as an example, CCW sells a 19x10" fr and 19x11" rr wheel setup with either 275 or 285/35 fr tires and 305/30 rr tires. SUPPOSEDLY you can put an 18x11.5" wide rear wheel (with the correct offset) with a 335/30-18 tire w/o rubbing or sticking out (or not very much, at least).
THanks for the feedback guys! What about the fronts? I want to get as much rubber on the ground all around without any worries of rubbing. Is a 19x10 285/35 it? What offset?
