rich on one side only???
Old Feb 27, 2007 | 10:35 PM
triblk6spd's Avatar
triblk6spd
Default rich on one side only???
just did a head swap and the car seems to be running fine, but seemed to be running rich. swapped form mti heads to afr's. the tune might be a bit off, but should be close. i pulled the plugs and just the pass side are black. the driver side is fine. any ideas? thank you.
-j
Old Feb 27, 2007 | 10:59 PM
Real Enthusiast's Avatar
Real Enthusiast
Pull the codes and see if you are getting any O2 sensor codes. It is possible that one of them is bad.
Make sure all of your plug wires are intakct and not broken.
Old Feb 28, 2007 | 12:33 AM
triblk6spd's Avatar
triblk6spd
no cel. the plug wires are tip top. any other??
Old Feb 28, 2007 | 12:36 AM
Real Enthusiast
No CEL alone isn't good enough. Pull the codes from the DIC code reader.
Old Feb 28, 2007 | 08:08 AM
see5's Avatar
see5
bad 02
leaking intake
leaking exhaust
Old Feb 28, 2007 | 08:42 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Check the DTC's!
This is the absolute best C5 Diagnostic Trouble Code (DTC) web site!!!
http://www.corvettedoctor.com/Code_Main.html
http://www.corvettedoctor.com/index.html
Go to “technical data base” and then to “Corvette ECM Computer Codes”. Then select your year car. Read the instructions and then scroll down to the "READ MORE" window to view the code definitions.\
Here is another very good site:
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix!!
Old Feb 28, 2007 | 11:12 AM
triblk6spd's Avatar
triblk6spd
i'll pull ther codes today then. thanks guys.
Old Mar 2, 2007 | 04:49 PM
triblk6spd's Avatar
triblk6spd
no codes. i replaced the o2 anyway. everything seems to be better. in 20 min driving everything was nice and clean. thanks guys.
To rich on one side only???
