Guys with new trickflow heads
Old Feb 27, 2007 | 10:39 PM
2000whitec5's Avatar
2000whitec5
From: 10.54 @ 129 346 N/A A4 Record 9.78 @ 139+ on 150 shot
Default Guys with new trickflow heads
with the trickflow 215 heads.. do you need to change the rocker arms? if so what type did you use ? thanks
Old Feb 27, 2007 | 10:43 PM
Real Enthusiast's Avatar
Real Enthusiast
I am pretty sure you have to change them. I think a lot of the guys are running harland sharp rockers.
Old Feb 27, 2007 | 11:15 PM
2000whitec5
1.7 ?
Old Feb 27, 2007 | 11:19 PM
thehammer69's Avatar
thehammer69
Originally Posted by 2000whitec5
1.7 ?
yes
Old Feb 28, 2007 | 01:27 AM
zeevette's Avatar
zeevette
You can use other ratios than the 1.7's if you want to, the main thing is, you need roller tipped rocker arms with the TF heads. I've got the HS, but Yella Terras, or Cranes are good too.
Old Feb 28, 2007 | 04:23 PM
6spd95's Avatar
6spd95
why do you need roller tip rockers? are the stock ones adjustable?
Old Feb 28, 2007 | 04:34 PM
zeevette's Avatar
zeevette
The TF heads have a narrower valve angle, which will result in uneven wear on the valve tips, if using stock rocker arms. The quick fix is roller rocker tips. And no, the stock ones are not adjustable.
To Guys with new trickflow heads
