Catch Can question....
Old Feb 28, 2007 | 12:01 AM
Miguels's Avatar
Miguels
Default Catch Can question....
So I installed the catch can that Willfulone and Cajundude sale.
I am having a hard time with the top cover having the nipples facing in the same direction. Is it okay to have the top cover not all the way tight?
Old Feb 28, 2007 | 01:29 AM
zeevette's Avatar
zeevette
Mine's the same way. Shouldn't be a problem, unless you see some seepage in time. You can always put teflon tape on the threads and re-install.
Old Feb 28, 2007 | 01:57 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Exactly.
As always if you have any issues with a CCA product, you can reach me at 571 264 4282.
I guarantee I'll take care of you 100%
Peace
Chip
__________________
..................Click for
Old Feb 28, 2007 | 05:05 AM
Gohard777's Avatar
Gohard777
Originally Posted by Willfulone
Exactly.
Peace
Chip
Well, you can't ask for anymore than that...bob.
Old Feb 28, 2007 | 11:19 AM
Miguels's Avatar
Miguels
Thanks for the replies.
Old Feb 28, 2007 | 12:02 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
i used teflon tape on the top elbow and it clocked just right. if you cannot get it to clock right, you may take the can apart and get the correct size pipe tap and go a tad deeper.
Old Mar 8, 2007 | 09:52 PM
CCA Corvette Parts
What ever it takes
Peace
Chip
Old Mar 9, 2007 | 02:42 AM
Beer99C5@FastbirdPerf.com's Avatar
St. Jude Donor '08
I snugged mine up using a cheesey rubber strap wrench, Was suprised how much they turned, also reopened to check the O ring to see if it was damaged it was not. Put it back together and snugged it up
Old Mar 11, 2007 | 10:05 AM
kww's Avatar
kww
Had the same problem-a little tape and bingo, problem fixed. I don't think you'll have a problem with the leak either. Mine is on really tight and theres enough thread so it's just not going to be an issue.
To Catch Can question....
