Rear Spring Bolts - Different Lengths
Old Feb 28, 2007 | 05:24 PM
bb609's Avatar
bb609
Default Rear Spring Bolts - Different Lengths
I just noticed my passenger side rear spring bolt is backed out all the way (no threads showing) while the drivers side is showing 5-6 threads. The car sits perfectly level in the rear and I never noticed a difference in the car in any way. Is it possible it came out of the factory this way? The car sits low to me but up until now, I haven't noticed that anything has been messed with on it. I bought it used with 2600 miles and just had it aligned a few months ago. What should I do about it now?
Old Mar 1, 2007 | 07:39 AM
bb609's Avatar
bb609
Morning bump....anyone?
Old Mar 1, 2007 | 10:45 AM
Alex1217's Avatar
Alex1217
St. Jude Donor '08-'09
The bolts don't necessarily have to be turned to the exact same position. the bolt on the left side of my vette shows about 3 grooves while the right side is almost all the way up. It was aligned and cornerweighted at a phoenix performance in PA when I had her lowered, which does suspension work for T1 Corvettes.
Old Mar 1, 2007 | 01:04 PM
FKING1's Avatar
FKING1
Don't remember the exact stock bolt/nut stock position. A search might find it. Measure the frame to ground height on a level surface. Sounds to me that your car is lowered as instructions for doing this are to leave 2 or 3 threads showing when lowering.
To Rear Spring Bolts - Different Lengths
