2004 Corvette Redline Problems?
Old Feb 28, 2007 | 11:03 PM
Mr. Couture's Avatar
Mr. Couture
Default 2004 Corvette Redline Problems?
Well I've been having a few problems with my vette. Not sure if it's a technical problem, but it's still a problem. Well I took my 2004 Automatic Corvette Hatchback to LACR to get a quarter mile run. I know automatics are more consistant and launch faster, so I figured I'd drop my car into 1st gear. As I wait for the green light, I take off, and as soon as I hit about 35 or 40mph, my car starts redlining it. Even while in drive, if I launch it, my car starts redlining, and I have to let go of the gas pedal, let the rpm's go down, and than give it gas. I don't know if it's a governor's chip or not. Well does a 2004 Vette even come with a governor's chip? I don't know, but I have to do something because I can't race my car
Any suggestions on what the problem is? Could it be technical problems, or the governor's chip(if it has one)? I'm open to all suggestions so give me your best thought..
This is driving me crazy
What to do, what to do?
Old Feb 28, 2007 | 11:49 PM
BanditDude's Avatar
BanditDude
It's hitting redline at 40 mph under full throttle, and you have to get out of the gas to resume acceleration? If so, it sounds like you're smoking the tires or the transmission is slipping.
Old Mar 1, 2007 | 12:10 AM
Mr. Couture
hmm, that might be. But as soon as I "punch it", in any gear, 1st, 2nd, 3rd or drive, it redline's it and I have to let go of the gas in order for the car to accelerate.
Old Mar 1, 2007 | 01:35 AM
Bill Dearborn's Avatar
Bill Dearborn
What do you mean by the term redline? It sure isn't what I think it is.
Bill
Old Mar 1, 2007 | 03:01 AM
Mr. Couture
Bill
What Does Redline Mean: Redline refers to the maximum engine speed at which an internal combustion engine and its components are designed to operate without causing damage to the components themselves or other parts of the engine.
Old Mar 1, 2007 | 05:54 AM
vettenuts's Avatar
vettenuts
From your signature, it appears the car is stock. If this is occuring in all gears, sounds like something is slipping. Have you checked the fluid level? Does it have the stock tune? (Some transmission functions can be tuned).
Old Mar 1, 2007 | 06:05 AM
Gohard777's Avatar
Gohard777
Bad converter?
Old Mar 1, 2007 | 08:54 PM
Mr. Couture
hmm, it's really hard to explain. The car is all stock, well it has borla exhaust, but that's it. If I'm racing from a roll, lets say 35mph, and I "punch it", I'll take off and then all of the sudden I'll be hitting the rev limiter, even if I change gears. I actually have to let off the gas in order to let the rpm's go down so I can continue to accelerate. Which means I can't race at all!
Do Corvette's come with governor chip's?
Old Mar 1, 2007 | 09:01 PM
vettenuts's Avatar
vettenuts
Sounds like you have a transmission problem to me.
Old Mar 1, 2007 | 09:14 PM
Mr. Couture
hmm, I'll look into it. thanks
Old Mar 1, 2007 | 10:43 PM
kyas's Avatar
kyas
Having same problem with my 2004 a4!!!!!!!! It only has 6,000 miles
on it, Vette dealership said tranny was in excellent condition...
Old Mar 1, 2007 | 11:06 PM
Mr. Couture
i know, it's not a good thing..
Old Mar 2, 2007 | 06:03 AM
vettenuts's Avatar
vettenuts
First check should be your fluid level and color.
Old Mar 2, 2007 | 09:17 AM
gpracer1's Avatar
gpracer1
Things to check.
Fluid level, when hot.
Fluid color, hopefully still red and not brown and burnt.
Line pressure.
Forward clutch pack.
Bad converter.
If it is slipping, it is time for a rebuild.
When an automatic trans slips more than 3 or 4 times, that clutch pack or band is toast.
If you put it in gear and hold the bake hard with ebrake also, then roll on the gas and see if it only goes to maybe 2K rpms or so. If it revs past 4K , then try the same in reverse and see if you get the same results.
Old Mar 2, 2007 | 09:57 AM
chaase's Avatar
chaase
St. Jude Donor '12
either way it doesn't sound good. The car should move into gear relatively quickly and there shouldn't be any need to let off the gas. I ran my car down the track many times in stock trim and that never happened.
Chris
Old Mar 2, 2007 | 09:50 PM
Bill Dearborn
Based on subsequent posts I see you really meant the Rev Limiter.
Bill
Old Mar 2, 2007 | 10:16 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
Since you live in California, would this be something you get from Schwarznegger?
Old Mar 2, 2007 | 10:53 PM
Mr. Couture
Bill
Yah, I'm sorry guys. I do suppose I meant the rev. limiter. But I guess you have to take into count that I have an automatic.
To 2004 Corvette Redline Problems?
