Squeaky belts!
Old Mar 1, 2007 | 02:57 PM
ro.co3's Avatar
ro.co3
Default Squeaky belts!
I have changed the belts about every six months on my 98 because they start squeaking. I've tried the belt dressings with no help and silicone sprays. This is getting old so any feed back is welcome.
Old Mar 1, 2007 | 03:42 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
goodyear gatorback belts stopped my squeaking. they're a little more expensive than normal belts but they will last longer.
Old Mar 1, 2007 | 05:09 PM
SLPRC5's Avatar
SLPRC5
but try and rub a bar of Ivory soap on the belts for now until you get the Gator Backs.
Old Mar 1, 2007 | 07:34 PM
ro.co3's Avatar
ro.co3
Believe it or not I have the gatorbacks, I've tried three different brands now with no luck. Every time I've put new belts on the squeak goes away for awhile so I didn't think it was a tensioner but now I don't know.
Old Mar 1, 2007 | 08:21 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
it's a possibility. The squeak could be bad bearings in the tensioner. It might also be the AC compressor but if it is the compressor you'll only hear the squeak when the AC is on.
Old Mar 2, 2007 | 03:45 AM
BowTieRocket's Avatar
BowTieRocket
Good likelihood of this with a '98. The serpentine belts more chatter when they are worn - the little ribs crack at odd intervals, and make a chirping or chattering noise in the pulleys.
The tensioner is a wear item. Mine folded up on me at 73k miles on my '99. Just leaned out about a quarter inch at the top and tossed the belt right off. Look at the gap on the tensioner - if you've been replacing belts, you know where the tensioner is. If the gap isn't dead even, the tensioner mechanism is failing. Even if that's okay, the pulley can squeal. So can the one on the idler, low on the driver side.
If you change one, I'd change all of 'em. An idler and a tensioner is in place on each of the two belts. Check that A/C belt while the main one is out - it's sort of buried, so while the main belt is off is a good time to look. With the speed with which these engines rev and drop off, the changes in thrust on the tensioners can cause some wear. Worth it for the effect of that power, though. :
Good luck. Not a big investment, but better than being stranded due to a belt failure. And if a new belt is thrown (as mine was), time for another new belt...
Old Mar 2, 2007 | 09:19 AM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
KILL THE MOUSE!!!
Old Mar 2, 2007 | 09:28 AM
ro.co3's Avatar
ro.co3
Thanks for the replies, I'm going to do some close inspections of my tensioner. It seems that the chirp is coming from the a/c belt but does not matter if the a/c is on or not. I'll let you know, thanks again.
Old Mar 2, 2007 | 02:06 PM
Fast one's Avatar
Fast one
Does this happen the first time you start the car in the day and then goes away after a minute or two? If so, it could be that the steel damper is rusting where the belt contacts it. My '98 had this problem until an aluminum ATI damper was installed and all the squeeking went away since there is no steel to rust. Someone posted that he cleaned the grooves on the stock damper and the squeeking went away for a while because all the surface rust was removed. If you live in a humid climate then rusting overnight could be the cause of the squeek.
Old Mar 3, 2007 | 08:01 AM
rws.1's Avatar
rws.1
when the belts are off, hand turn/spin each of the pulleys.
They should spin freely and smoothly without any wobble or play.
If one of them wobbles, does not turn smootly or feels gritty , you have found the problem
Old Mar 3, 2007 | 08:05 PM
ro.co3's Avatar
ro.co3
Thanks for the replies, hope I can find the time next week to look at the tensioners. Also it makes the squeak pretty much all the time.
Old Mar 3, 2007 | 08:10 PM
TEXHAWK0's Avatar
TEXHAWK0
Also, the GM service manual specifically states NOT to use any type of belt dressing on serpentine belts. It causes belt deterioration and may be adding to your problem.
Old Mar 6, 2007 | 01:13 PM
SilvaDragon's Avatar
SilvaDragon
My '99 was doing this. Belt dressings always made the problem
worse over time, after helping for a short time. After replacing
the belt several times I took a good look at all the pulleys and
found one of the composite pulleys had a chunk taken out of it!
Anyway, one more thing to look for...
Old Mar 6, 2007 | 01:40 PM
RB Racing's Avatar
RB Racing
It was the idler bearing on my 2000, took it apart put grease in and the noise was gone.
Old Mar 6, 2007 | 07:58 PM
3 vettes's Avatar
3 vettes
Default squeaky belts
if your belts are new or in good shape with no cracks the noise is probably from glaze on the pulleys.this may sound crazy but it really works.i read it in a hot rod magazine a long time ago.try rubbing a little bit of toothpaste on the ribs and back of the belt.the fine abrasive in the toothpaste will clean away the glaze on the pulleys leaving them a little dull looking instead of shiny.this will keep the belt from slipping on the pulley which causes the squeak.valve grinding compound is good also if the glaze is very heavy.i am the foreman of a large nissan dealership service dept. and we have been doing this for years with 100% success.the factory will not pay for belt adjustments after 12,000 miles and the customer refuse to pay because they feel the car is still new,so this is the perfect solution.plus when you open the hood the engine has a fresh minty smell.(just kidding)
Old Mar 6, 2007 | 08:11 PM
B-rent's Avatar
B-rent
I keep having the same problem even after 2 belts. Im going to see my mechanic at the race shop thursday to look into it. Ill let you know what he thinks my problem is
Old Mar 6, 2007 | 08:25 PM
jedblanks's Avatar
jedblanks
I replaced the following:
Tensioner Pulley -- no fix
Idler pulley -- no fix
Removed belts -- fixed
Put AC belt on -- tiny sqeak
Replaced AC belt with GATES belt -- no squeak with this belt only
(comparable in price to gatorback, always been partial to gates)
Put original Main Serp belt back on -- squeak back
Replaced main belt with Gatorback ($25 at autozone -- gates was $42, so I went with gatorback on everyones recommendation)
So far fixed. I still have a slight crank pulley wobble that I think could be the cause of the problem over time and I will be looking into that further - but so far 40 miles today squeak free.
Old Mar 8, 2007 | 06:40 PM
B-rent's Avatar
B-rent
Mine seems to be the idler pully. We had to order one from Vortech soo ill just wait and see if that takes care of it
Old Mar 8, 2007 | 07:57 PM
POK868's Avatar
POK868
I had an annoying squeak finally went away when I replaced the crank pulley, it was a wobbler, if your squeak is persistent this is probably the cause
To Squeaky belts!
