Changing auto trans question.
Old Mar 1, 2007 | 03:07 PM
jeff49's Avatar
jeff49
Default Changing auto trans question.
When I bolt the pan back on the transmission do you use a gasket sealer on the gasket.Im worried about contaminating the inside of the transmission.Or just use the gasket alone. Thanks for help Jeff
Old Mar 1, 2007 | 07:49 PM
2000BSME's Avatar
2000BSME
Permatex gasket sealer would be acceptable in a water pump installation, but no, not in a transmission pan installation. The bolts that hold on the transmission pan are special and flanged (if memory serves me correctly), and they will be ruined if you over-torque them. Use a guide to show you the correct tightening pattern, and don't exceed the torque value, even if you have to go out and buy your own torque wrench! Don't use any sealer.
Old Mar 2, 2007 | 12:05 AM
jeff49's Avatar
jeff49
Thamks for the tip
To Changing auto trans question.
