need valvetrain help
Old Mar 1, 2007 | 09:17 PM
c5vette_dallas's Avatar
c5vette_dallas
Default need valvetrain help
we put heads and cam on my friends 99 TA...it ran awesome when we put it back together this week.... now some of the pushrods/rockers will not move(go up or down) any inpu on this guys?
Old Mar 1, 2007 | 10:39 PM
Blown 346's Avatar
Blown 346
What did you torque them down to? They should be set at 65 Ft LBS, they are self adjustable and will adjust themselves. Make sure the pushrods are seated in the lifters.
Old Mar 1, 2007 | 10:50 PM
msghuff's Avatar
msghuff
WHAT???? NoNo 22ft lbs on the rocker bolts
taken from ls1 howto:
Insert all 16 pushrods (7.400" is probably needed unless you have highly milled heads or a small cam, in which 7.350" might be needed), place pedestal back on the head, apply locktite to all the rocker center bolts and reinstall all the rockers. Torque the rockers to 22lbft.
Now, using your 24mm socket wrench, turn the motor over by hand (should be difficult as you are now building compression) and make sure the motor turns over by hand a full 720 degrees, then turn it another 360 (doesnt have to be exact or anything).
Go over all the rockers again with your wrench just to make sure they are all at 22-24'ish lbft.
Old Mar 2, 2007 | 01:09 AM
Jay-rod's Avatar
Jay-rod
Your cam is wiped out(no lobes left) if you are rotating the crank and not all ofthe rockers are moving.You probably overtorqued the rockers.JER
Old Mar 2, 2007 | 01:41 AM
Blown 346's Avatar
Blown 346
[/I]
My bad, I was thinking head bolts.
Old Mar 2, 2007 | 05:58 AM
vettenuts's Avatar
vettenuts
Overtightening the rocker bolts won't have any affect on the cam load since the bolts are seating the rocker fulcrum to the head.
Old Mar 2, 2007 | 06:00 AM
vettenuts's Avatar
vettenuts
Are the rockers bolts still tight?
Are the rockers stock?
What heads?
Is it all the rockers?
Need more information, but it almost sounds like a broken timing chain.
Old Mar 2, 2007 | 08:43 AM
c5vette_dallas
ok.... sry..had to go to work last night...
they are AFR 205 heads with a G5-X3....brand new... its not that all of the rockers are not moving...just a select few... even when the rockers are off and we are puttin pressure on the pushrods... the pushrods still dont move and the rocker is sticking up high... its as if the lifter is gettin stuck up higher in its hole and not moving... yes the rocker bolts were still tight... they are harland sharp 1.7 roller rockers..
Old Mar 2, 2007 | 10:37 AM
vettenuts's Avatar
vettenuts
So pushing down on the push rod with your hand, if you turn the motor over the pushrod doesn't go up and down on only some?
Old Mar 2, 2007 | 10:42 AM
FRCTony's Avatar
FRCTony
You need to tell us exactly what the problem is. Then we can tell you what is wrong
Does the car run? How does it run?
What prompted you to look at the valvetrain?
Old Mar 2, 2007 | 12:25 PM
msghuff's Avatar
msghuff
[QUOTE=c5vette_dallas;1559192951]the pushrods still dont move and the rocker is sticking up high... its as if the lifter is gettin stuck up higher in its hole and not moving... QUOTE]
This sounds like the lifters are frozen..Wich ones dont move? Are they side by side or not? Regardless removing the head and inspecting the lifters and bore would seem like a good course of action.
Old Mar 2, 2007 | 06:39 PM
vettenuts's Avatar
vettenuts
On a rare occasion, the lifter bores in the LS1's have been found to be an issue. Also, you may need to check to see if any of the lifter tray's are a number "10" some of which didn't provide correct lifter alignment. I would think the spring would push a lifter back down unless it has serious issues and if it won't go down it likely won't come up either.
Old Mar 5, 2007 | 11:56 AM
Boob's Avatar
Boob
When in doubt disassemble and reassemble.
To need valvetrain help
