Knock Sensor wiring issue
Old Mar 1, 2007 | 10:55 PM
PhreekZ's Avatar
PhreekZ
Cruising
Default Knock Sensor wiring issue
I found that I caught the Knock sensor wires between the block and the manifold when i was replacing my oil pressure sensor. I took the manifold back off and put it where it needed to go and cleared the codes off. I drove it for about 15 min. and the check engine light came back on. I'm assuming the wires are messed up. Whats the best way to go about repairing or replacing the wiring for the KS?
Old Mar 2, 2007 | 12:35 AM
PhreekZ's Avatar
PhreekZ
Cruising
TTT - I'm hoping to figure this out tonight so i can get this *&%$ fixed... I'm hoping to get everything smoothed over cuz i'm thinkin about tradin in on a C6
Old Mar 2, 2007 | 12:56 AM
Jay-rod's Avatar
Jay-rod
Can You splice a new section of wire in?
To Knock Sensor wiring issue
