Electric Water Pump install question
Old Mar 2, 2007 | 08:21 AM
SCannon's Avatar
SCannon
Default Electric Water Pump install question
What is the best way to wire up a electric water pump on my C5?
Old Mar 4, 2007 | 11:14 AM
Laguna Blu's Avatar
Laguna Blu
Not sure about your answer SCannon but I'll bring this post up to the top for you. My factory water pump is beginning to leak and I'm wondering if it is worth the extra cost of upgrading to an electric pump or should I just buy a new factory unit from GM?
Old Mar 4, 2007 | 01:16 PM
Carol & Lee's Avatar
Carol & Lee
Ttt
Old Mar 4, 2007 | 05:28 PM
ICaughtVetteFever's Avatar
ICaughtVetteFever
Here you go:
http://ls1howto.com/index.php?article=27
Old Mar 4, 2007 | 07:20 PM
willyfastz's Avatar
willyfastz
Just ground it, and pick a wire like your fuel pump wire as the power and your good to go. Or if you want to be able to circulate your water while the car is off just pick one of the other switched hot wires (under the fuse block) so that you can turn the switch on and the pump will run. And I would recommend using a relay also.
Old Mar 5, 2007 | 06:06 PM
SCannon's Avatar
SCannon
You can power the fuel pump and the water pump off the same wire? I thought the water pump would need its own power.
Old Mar 5, 2007 | 06:52 PM
99blackFRC's Avatar
99blackFRC
Yeah, if you want to half *** it Pick up a relay from radio shack or an automotive store and switch B+ to the WP and play it safe.. They draw a good amount of current so why take the risk?
Old Mar 5, 2007 | 10:21 PM
SCannon's Avatar
SCannon
I have a 30 amp relay. I was going to power it off the back of the alternator and use a key on wire to power the relay.
To Electric Water Pump install question
