Clutch Install Help
Old Mar 3, 2007 | 09:37 AM
Watch22's Avatar
Watch22
Default Clutch Install Help
I’m getting ready to swap my stock clutch out for a Textralia 0Z700 that I got from ECS’s last GP. I already bought a new slave/throwout/pilot bearings and remote bleeder. I have a couple of question on the balancing of the Flywheel/Pressure plate.
I keep reading about some people just having there Flywheel/Pressure plate zero balanced then install? Or do you have to balance the old stock Flywheel/Pressure plate to the new Flywheel/Pressure plate?
Old Mar 3, 2007 | 10:51 AM
itchynackers's Avatar
itchynackers
I just got my textralia on the GP too. I asked Chris at ECS this very question, and he said they were zero balanced already. I guess I'm not sure about balancing with the old stuff.
Old Mar 3, 2007 | 01:54 PM
vettenuts's Avatar
vettenuts
Here is what I understand, the original may not be zero balanced. Check the old one, if out of zero then re-balance new to same non-zero balance. Just make sure on disassembly you mark all the parts and locations so if you have problems later you can reconstruct the crime scene.
Old Mar 3, 2007 | 02:19 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
The LS1 is a internally balanced engine meaning that the internal rotating assembly is zero balanced as well as the harmonic dampner and the whole clutch assembly. Whit that being said I have had a few cars where the engine was built and something was not in perfect balance so it was made up in the clutch assembly. Now this was maybe 3-4 cars in all of the clutch jobs we have done. I dont double check the stock clutch for zero balnce when we do clutch jobs but I never throw away the original clutch untill the new one is in and the balance is fine just in case I have to have them matched. The Textralias are all zero balanced so they are able to be installed right out of the box..
Old Mar 3, 2007 | 02:26 PM
Geneus's Avatar
Geneus
Damn...that sounds very profound...I'll buy one.
Isn't it Saturday? Why are you still working?
Old Mar 3, 2007 | 07:31 PM
Watch22's Avatar
Watch22
Thanks for the reply's, I will be tackling this later next week. Anyone have any tips for the remote bleeder?
To Clutch Install Help
