Evans Water Pump question - HELP :-)
Old Mar 3, 2007 | 10:38 AM
98VertPDX's Avatar
98VertPDX
Default Evans Water Pump question - HELP :-)
Hi,
A while back I bought an Evans waterpump from A&A. I sold the car before getting a chance to install the pump, so I am selling the pump.
A potential buyer is saying that the pump requires special coolant fluid (from evans) Is this correct? Can anyone confirm or deny?
Thanks in advance,
Luis
Old Mar 3, 2007 | 10:52 AM
thehammer69's Avatar
thehammer69
Originally Posted by 98VertPDX
Hi,
Thanks in advance,
Luis
No, you don't have to use the Evans coolant with the pump.
Hammer
Old Mar 3, 2007 | 10:53 AM
98VertPDX's Avatar
98VertPDX
thehammer69,
Thanks for the quick reply...
Luis
Old Mar 3, 2007 | 11:37 AM
YBNORMEL's Avatar
YBNORMEL
Found the same results on LS1 tech, Clear out your PM's.
Old Mar 3, 2007 | 11:44 AM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
Best pump on the market and you can run any coolant you want.
charlie
Hi,
Thanks in advance,
Luis
Old Mar 3, 2007 | 06:49 PM
98VertPDX's Avatar
98VertPDX
charlie
Excellent! Thanks for the info, I have cleared my PMs...
Regards,
Luis
Old Mar 3, 2007 | 08:46 PM
Tomulrich's Avatar
Tomulrich
you have to run evan coolant with the pump....there are some changes that need to be mage to run regular coolant...call Evans they will tell you...instructions state this as well..
Tom
Old Mar 3, 2007 | 09:28 PM
NemesisC5's Avatar
NemesisC5
charlie
What attributes makes Evans the best ? Is it best suited for 1/4 mile, road course, street, or does it cool better in all applications ? I have done everything I know of to make my car run cooler and be consistant except for changing water pumps. I thought about a Meziere electric pump but heard they would not flow enough for road course events to keep my car cool. In another case I once installed a "high flow" water pump on a 82 Z-28 and the car ran hotter; I speculated that the coolant was not held in the radiator long enough to cool the engine. If I recall correctly the Evans is a very high flow unit, around 140gph I believe
Old Mar 3, 2007 | 11:53 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Tom
Hmmmm... I wonder what those changes are? I bought my Evans WP from A&A years ago and have been running conventional coolant through it without issue.
Old Mar 4, 2007 | 12:20 AM
NemesisC5's Avatar
NemesisC5
I found this intersting writeup
http://www.evanscooling.com/articles/nov97ts.htm
To Evans Water Pump question - HELP :-)
